Is it ok to use wheel bearing grease over thermal grease?
silen
Dan did a great comparison of thermal interface materials and even included some odd choices...
* No grease at all
* Plain white silicone grease
* Arctic Silver 3
* Arctic Alumina
* Cooler Master PTK-001
* Cooler Master HTK-001
* Nanotherm
* Toothpaste
* Vegemite
That toothpaste looks like it works pretty good!!
Aug 16, 2001
22,505
4
Originally posted by: RussianSoldier
I was installing a couple processors and I ran out of thermal grease. Instead, I just used some standard wheel bearing grease. Was this an ok move? Or should I have used marine grease instead?
Seriously? Yes it will work. Grease can take high temperatures.
Maybe you have seen the site with the guy using toothpaste, vegemite and water as paste and it works good.
Jeff7181
18,368
11
Originally posted by: MDE
Originally posted by: SpitFire
ONLY 65 C!!! Are you crazy, are you trying to fry the processor! I don't even want to know what its at under load.
65C isn't all that hot. Sure, it's high, but nowhere near enough to kill the chip. I'd go out and get at least a packet of the cheap silicone paste though at the very least. Sure the bearing grease works for now, but I'd only use it for a temporary fix.
Nevermind that it will contaminate the mating surfaces and make EVERY future application of THERMAL COMPOUND less effective. Oil is absorbed... it's impossible to clean it all out even with alcohol or brake cleaner which is why Arctic Silver says not to use WD40 to clean the surfaces before applying Arctic Silver.
im2good4u
93
sheeeeesh, what a thread this has become.:laugh: BTW based on the comparison toothpaste works in the level of AS3 even better, wonder what brand is that TP?
Jeff7181
18,368
11
I don't think I'd want an abrasive between my heatsink and CPU core... a CPU with a heatspreader, maybe... not definately not an Athlon XP.
Zap
22,377
LOL, this is pretty funny. I think it may actually work. Hmmm, I've got some teflon grease that I bought at a bike shop. It looks kinda like the basic white thermal compound. I'm willing to bet that it works better than using nothing between the CPU and the heatsink. Don't think I'd risk any of my good CPUs on this, but perhaps an old socket 370 Celeron or something...
ThunderPC
66
Coat the mating surfaces with the Crisco first. Then squish the toothpaste between it. Heck the mild abrasive in toothpaste might help polish the mating surface for you. Hmm that might be bad after all... then all my Crisco would run out quicker :( . I love that french fry smell while gaming.
Zebo
39,398
19
Teflon is a horrendous idea since it's one of the best temperature insulators.
Generally speaking materials that are good electrical conductors are also good equivalently good heat conductors....Hence copper wire and copper heat sinks.. and why toothpaste worked just fine (until it dries of course)...and teflon would be about the worst choice.
gwag
608
toothpaste works fine, sure you can polish a heatsink with it but unless you heatsink moves back and forth alot the abrasive won't hurt anythig.
DrMrLordX
22,560
12,426
I want to try using something more exotic as a heat-transfer material between my cpu and heatsink. Therefore, I shall be removing my standard thermal compound soon and replacing it with the SOULS OF THE DAMNED!
Do you think it'll work? Normally they spend all their time in Hell or some other malevolent, flaming pit. I'd say their pretty heat-resistant. All their wailing and gnashing of teeth may make for a noisy rig, though. Thermal compound removal will require an exorcist as well. Is it bad to get pea soup inside one's PC?
Jeff7181
18,368
11
This is the dumbest thread ever. All you people are throwing out silly ideas in jest, and some noob is gonna come read it and be like "he said I can use toothpaste" and slop toothpaste all over his CPU and then be surprised when it doesn't work in 6 months.
Noid
2,390
193
I'm using bubble gum that was stuck to my shoe :thumbsup:
rgreen83
766
Originally posted by: sisooktom
Why don't you just use kerosene?
I tried that! Im pretty sure it worked great too, my computer has never been so cool as when the firemen were spraying it with flame retardent foam.
alexXx
502
on another note, can i use the facial oil from everyone i know to lubricate my car?
