Is it hard to get a security clearance?
Aikouka
30,383
912
Originally posted by: zuljinAF
TS typically takes 2 years or more and cost 80-85 grand on average (this from when the investigation is started NOT when you submit the paper work, that can take another 2 years depending on the urgancy of the request). a Secret clearance is 6 months to a year, and cost considerably less. Also if your stuck using EPSQ i feel sorry for you! The new EQuip is MUCH easier and makes the process faster as the agencies that do the back checks are doing the EQuip submissions before EPSQ.
Do you mean the online EQuip setup?
Originally posted by: bignateyk
Took me less than 2 months to get my Top Secret. Im not gonna mention it here, but there are ways to get it done quickly. It just depends who is gonna be holding your clearance, and how badly they want you to have it ;)
Aw, spill the beans!
Codewiz
5,758
Originally posted by: Spartan Niner
As long as you aren't Middle Eastern or look like a terrorist...
You have no idea what you are talking about....
I work with two arabic muslims who have clearances........
Ignorance is bliss......
patentman
1,035
Depends on the level of clearance you need. I had TS-SCI (top secret secure compartmentalized information) clearance when I worked for the Naval Research lab. It took me about 14 months to get it, however. Be completely honest on your application. Drugs, crimes, etc... spill your guts. They are going to find out anyway, and its better to be honest than not say anything, as silence is considered lying by omission during the background check.
zuljinAF
43
yes the online version, and I didnt have to psych eval for my clearance just my job...
homercles337
6,340
Originally posted by: Deeko
So I got a job offer from Lockheed, but its contingent on me getting a security clearance. Is this pretty standard?
If you havent been a straight arrow your entire life then it is very difficult. Also, you should also be a practicing xian. Apparently, they look down on "amoral athiests."
homercles337
6,340
Originally posted by: purbeast0
are they going to sponsor it for you? or do you have to get it yourself?
typically jobs will get it for you. if so, that's gold.
You HAVE to have a sponsor. You cant try to get clearance for no reason.
