is having dts audio better then non dts audio
Status
Not open for further replies.
Rayniac
78
13
41
Isn't DTS just a digital audio compression format that is used to transfer more than 2 channels through an interface that normally supports only stereo? Do you need that?
DominionSeraph
8,386
32
No, DTS is an ancient fully multichannel codec.
This looks to just convert to DTS for output over S/PDIF. Pointless because you're likely not going to be hooked up to a DTS receiver, and even if you were it would be better to just use LPCM.
Reactions: Rayniac
Status
