yellowperil
- Jan 17, 2000
- 4,598
- 0
- 0
Doesn't drinking water only have trace amounts of minerals? I wouldn't think the difference from distilled water is that great - it seems drinking water would still absorb a lot of minerals, but distilled water a negligible amount more.Originally posted by: Eli
That site is pretty sensationalistic, but.. the points he brings up are very interesting!Originally posted by: jumpr
As long as it's not distilled water, you're in great shape. Distilled water basically SUCKS all the nutrients out of your soft tissues.
http://4optimallife.com/Distilled-Waters-Danger-To-Health.html
It is very true(although I do not know the extent; ie: if it's as bad as this guy says) that water with no TDS(total dissolved salts) will actively absorb just about anything that can be dissolved in water.
The same is very true for plants. You can NOT give ANY plant distilled water unless it is to flush a toxic buildup of salts(elements, minerals). Since the concentration of salts in the plants' system is higher than that of the water, osmosis will halt the absorbtion of dissolved salts.. and actually start removing them from the plant.
So on that level it makes sense. Pretty interesting... I never thought about that for people..
I'm skeptical about the CO2 absorbtion/acidic thing. I'm pretty sure distilled water has a PH of 7.0 ....
I don't buy the 'distilled water in cola' argument in that article because too many confounding (and more important) variables - drinking Coke made with distilled water gives you more degenerative diseases than with tap water? C'mon. That's not even a reasonable inference from the data, I would think. Neither is the title that 'early death comes from drinking distilled water'.
