Is Desktop Haswell a dud? How many are not "upgrading"?
BSim500
1,480
216
The more I read about Haswell's desktop chips, the less impressed I am becoming, all aspects. :\
To summarize:-
- It runs hotter than IB and still uses the same crap-TIM material with the same unwanted 0.2-0.5mm "gap" between core & heat spreader requiring high-risk delidding to reduce temps back to 10-15c lower Sandy / Nehalem performance. Claiming it's due to "cost" is nonsensical given that Sandy & Nehalem Pentium & Celeron chips were soldered without cost issues.
- In theory it's 10% faster, in practise it's as little as 1% in many games (eg, Skyrim is only 1%, WinRAR only 4%)
- It uses more power under load than IB despite the fact the entire "Haswell" concept is about power efficiency. Some benchmarks even say it uses more when idle...
- It's more expensive than Ivy Bridge even factoring in performance.
- i5/i7 "K" owners - It appears to have a 5% (200-300MHz) lower overclocking potential than IB over 4.5GHz instantly nullifying much of the IPC speed gain. +85c at 1.3v @ 4.5GHz with high-end aftermarket coolers? Ouch. Literally. From what I understand, this is due to the now integrated regulator automatically increasing voltage by 0.1v at high loads (whereas before on the motherboard, you had to manually compensate for "droop" which can vary between power supplies). I also understand that whereas before you could tweak the various motherboard settings, now you can only disable the effect by locking the voltage which disables all power-saving technologies, sending Haswell's idle power consumption soaring. So you either put up with higher temperature or sacrifice power savings in idle mode. For a CPU specifically marketed as a "power saver". "Genius". :thumbsdown:
http://www.xbitlabs.com/articles/cpu/display/core-i7-4770k_12.html
- i5/i7 "K" owners - "K" chips don't support TSX-NI, vPro or VT-d extensions for no technical reason whatsoever
- i5/i7 non-"K" owners - It no longer allows +400Mhz "4 bins" overclocking on non-"K" i5 chips. 4570 (3.2GHz / 3.6GHz turbo) is stuck at 3.6GHz vs 3470 (3.2GHz / 3.6GHz turbo + 4-bins = 4.0GHz). Since Haswell hits +10% IPC efficiency only in a very few apps, this means that a 3.6GHz maxed 4570 is now slower on average than its 4.0Ghz maxed 3470 Ivy equivalent...
http://www.hardware.fr/articles/897-6/overclocking-plus-libre-k-plus-strict-par-ailleurs.html
- i3 dual core owners - BCLK overlocking is only allowed on "K" i5/i7 chips (but there are no unlocked i3 "K" chips) meaning 3.3GHz i3 Haswell's stuck at 3.3GHz *still* run no faster than 3 generations old Clarkdale i3-530's which could be BCLK OC'd to +4.2GHz and then some. 0% improvement over 3 generations is a catastrophic failure for dual-cores. Real-world examples:-
i3-530 @ 4.2Ghz = 3,818KB/s WinRAR. (Clarkdale)
i3-2120 @ 3.3GHz = 3,304KB/s WinRAR. (Sandy)
i3-3220 @ 3.3GHz = 3,557KB/s WinRAR. (Ivy)
i3-4220 @ 3.3GHz = 3,702KB/s WinRAR*. (Haswell) - predicted with 4% avg IPC boost vs Ivy.
It's pretty sad if it's going to take a Broadwell i3 just to match a Nehalem due to crippled OCing on dual-cores. o_O
The 4 generation ride was a great seamless stream of improvements (Core 2 Duo -> Nehalem -> Sandy -> Ivy), but this one has somehow managed to screw over almost everyone simultaneously, each for different reasons...
Personally, I'd have been happy with the IPC improvements had say, the chip been soldered and temps were reduced by 10-15c. Or if BCLK OCing had been for all chips, not just limited to "K's". Or if an i3 "K" chip came out for the return of budget overclocking. Or if "K" chips didn't have TSX-NI unnecessarily disabled. So far though, everything seems to be one downgrade / compromise or another that isn't an "upgrade" at all...
Your thoughts?
aigomorla
21,073
3,576
to me...
haswell is bulldozer...
like bulldozer.. Intel fubard, but unlike AMD, they only fubard the desktop line.
So no... i am not going to be fed what intel wants us to us.
I'll skip this generation and the entire desktop line if i need to.
Thank god server line wont see this crap..
If data centers saw this crap, intel would get chewed out majorly.
Increased heat load for near or same clock performance is totally not acceptable.
exar333
8,518
8
to me...
It is an interesting trade-off. 10% less load power and 20% less idle power usage vs. Ivy. BUT temps are almost inversely the same percentages (10% higher load and 20% higher idle).
Haswell is great for stock CPU speed usage, power consumption, and mobile usage. Unfortunately, it starts HOT and stays that way. Reminds me a lot of Bloomfield actually...
WhoBeDaPlaya
7,415
404
Uhm, Bloomfield was a piece of cake. Here's mine that's been running under a Xigmatek Dark Knight on the same settings to this day from 2009 :
386user
66
mobile isnt looking too hot either...
for the first time,,its looking like a macbook air might be a cheap 'ultrathin'
edit::....well...OEMs and intels fault..
700, 800 ultrabooks they were talking about? dont see any...most are 1200+
RU482
12,689
much like the rest of the computer industry, desktops are now an afterthought
tweakboy
9,517
www.hammiestudios.com
Im waiting for September 24th when Ivy Bridge E comes out. Im grabbing the 600 dollar 4930k ... OC to 4.8ghz yaaaaaahooooooo , I see 12 in speedfan or task manager. I run Sonar X2 Producer and my projects use avg 35GB to 45GB RAM right now. Thx gl
Beavermatic
374
8
So whats the next big thing after Haswell that I should put money towards?
I'm opting out from upgrading from the 3770k to the 4770k... primarily because it offers little to no gain over my current processor.. but whats the next lineup?
I'm getting sick of quad core. I went from a Q6600 to a Q9650 to a SB 2600k to a IB 3770k, and thats been over a span of nearly five years, all friggin quad core. I'd go to a 39xx series processor, but I'm not dumping $550 into a processor. Any reason to think we will start seeing socket 1150 $~340 processors within the next several months that have 6 cores or more?
Edit: Guess it looks like Ivy Bridge-E series due out in September looks like the performance successor, in the 49xx series convention. And will have upto 6 cores/15mb L2 cache. I'm assuming it will work on my current 3770k board? Or will I need a new mobo as well? Looks like Haswell-E not due out until mid 2014
Bill Brasky
4,324
Six core 1150 cpu within *MONTHS*? 100% no. Speculation says intel won't release six core parts on the mainstream lineup until Skylake at the earliest. You're best bet to get a six core part cheap is this summer on fleabay etc, or when ivy-e is released you might find some sales for sb-e.
No, the E series processors use a different socket and a different motherboard. 3770k -> socket 1155, 3930k -> socket 2011.
Pheesh
138
No it will not work on your current 3770k board. IVB-E like SNB-E uses 2011 socket (it's based on the server xeon die's).
There is no chance of a true 6 core CPU on 1150 socket in the next several months or even a year+.
Btw Q6600 and Q9650 were quad core and could deal with 4 threads, but 2600K and 3770k can effectively deal with 8 threads. You're currently getting a lot of the performance aspects of what would be an 8 core CPU, but without 8 true cores.
IVB-E will have 6 core/12thread options much like SNB-E. What do you use your system for that you believe would demand more cores than you currently have?
Edrick
1,939
230
to me...
Over the years, I have always liked your posts. And you seem very knowledgeable and experienced. But this is the dumbest thing I have ever heard you say.
Intel succeeded in their goal (Mobile). And their new instruction sets are huge. Just because it is not the Uber gaming CPU, everyone is all bent out of shape. There is more to CPUs than gaming and OC records.
VirtualLarry
56,587
10,225
Excellent summary of the issues posed by Haswell, OP. Thanks for posting, and yes, I think that this deserves its own thread.
I think this really signals the "beginning of the end" for desktop. The writing is on the wall. Hold on to your 3770Ks, folks, the rides all downhill from here on desktop.
Beavermatic
374
8
Hmmm... well I do zbrush, 3dsmax, maya, graphics intense games etc... but even those seem to run perfect currently. Course I'm assuming that's from the 32GB of RAM and dual Titan's I have in here now vs. my 3770k.
Im probably really looking at the wrong market for majority of what I am now doing.... all 3d modeling/3d rendering. I probably should start looking into dual Xeon platofrms and Quadro cards... couse I play a fair share of games, and I heard such platforms have hit/miss support and issues with games, hence why I've stuck with higher end gaming market hardware (which in itself probably isn't the prime choice for 3d development, but hell, I have to choose what side of the fence at one point or another)
Guess I'll just wait until the ivy bridge-e comes out, suck it up, grab a different motherboard too.
Wonder why Intel is delaying mainstream 6-cores plus so long? I know the threading and whatnot give a current quadcore a resemblance to octocore performance, but just feels like we've been stuck on quad's for far too long.
Should i go ahead and grab a 2011 motherboard and just backburn it in the closet until Ivy Bridge-E comes out? Or should I wait until Ivy Bridge-E's actual release?
meloz
320
I just wish they used better TIM with Haswell, and do something about that 'gap' which keeps the temps high. :( Then it would have been an easy choice to upgrade. I do not think desktop Haswell is a complete failure, Intel is merely holding back its punches as usual. Profit margin > performance.
Haswell still makes eminent sense for those using pre-Sandy Bridge CPUs. Those guys will see an easy 'real world' 20-30% boost in most scenarios.
For SB and IVB users an upgrade to Haswell only makes sense if you are a software developer who needs to compile with AVX2.
LOL.. well yes. More like the end of 2014 though.. hopefully.
They have not even launched IVB-E, as yet. No way large socket Haswell is being released in 2014.
Revolution 11
952
79
The TIM is fine, maybe even better than most commercial TIMs. The heat is probably due to the gap between between the IHS and the die as well as the FIVRs on the die.
I wonder if there are more steps to delidding and managing a bare-die Haswell compared to Ivy Bridge.
