SpeedTester
- Mar 18, 2001
- 995
- 1
- 81
Brandon, why on your task manager pic do you not have any history? It's just pegged at 100% on your overall scale? Did you snap a pic right when you started stress testing?
My suggestion it to leave the bus alone and up the multiplier. Voltage range typically should be 1.25-1.35v (I think 1.4-1.45v is pretty much max 24/7 if your cooling can handle it). You have other tweaks you might have to make such as PLL voltage.
Jacking up the FSB can lead to corrupted files and various other instabilities. Im shocked you got it as high as you have already by just upping the fsb.
so what with bus speed guys ? leave it to 126mhz or change multipiller and set bus speed to 100 mhz ? i have no idea how to change other variables![]()
can i do that thng ? :
set overclock to auto ..... then change multipiller to 44 and bus speed to 100 mhz .... so just let "auto overclock" to manage other variables and manually just change multipiller and bus speed ya ? and also i think it would be better to don't touch voltage also and leave it at 1.3 .. i hope that will be enough for 4.4 GHZ ....
now about heatsink .... what can you recommend me guys instead my heatsink ? to keep CPU cooler ... under 60-65 altime with 4.4 GHZ
stop off top please and help me guys![]()
Easy quick settings
Oc settings - set to manual
Multiplier - 44
CPU v - 1.3-1.35v
You should post pics using core temp, Intel burn test or similar and let the system heat up watching temps for a couple minutes. How much do you want to spend on a cooler? I own the d14 and love it but you could also run one of the all in one water coolers.
