Is Advanced Thought Incompatible With Extreme Strength?
lxskllr
60,873
11,217
That gorilla vid in the Hume thread got me wondering why humans are so weak. We're some of the least physically capable animals around. For most of human history, high strength would be pretty close to being as valuable as intelligence. Why don't humans have both? Is there some reason both attributes can't easily coexist, or is it just a fluke of evolution?
pete6032
8,413
3,807
Maybe the smarter you are the less you have to rely on strength. You can create tools or weapons or fees yourself. So the most desirable mates aren't necessarily the strongest ones anymore but the smartest ones.
35,487
The brain uses a lot of energy and oxygen. Maybe we had to pick one or the other.
lxskllr
60,873
11,217
That's the direction I was leaning in, but I'm not certain what that means in absolute terms. Nutrition was fairly hard to come by til recently, so perhaps there wasn't enough to support both. The selection process is interesting though. Say 50k years ago. There's only so many ways to smart yourself through life, and I'm not sure it would be as readily distinguishable to potential mates as brute forcing your way into food/possessions/social power
dank69
37,617
33,336
What evolutionary purpose does the gorilla's strength even serve? Don't they eat plants?
Feb 4, 2009
35,862
17,407
Climbing trees & beating up other gorillas and/or scaring off predators so they can mate is the purpose.
Edit:
Darn it Ironwong beat me however not in a gorilla beat down way.
GodisanAtheist
8,533
9,969
It's a layered question. Couple of things going on:
Chimps and Gorillas are stacked because of their muscle composition. They sacrifice fine motor control for ass kicking ability. Incredible if you have to beat the shit out of another 800 lb Gorilla, terrible for interpretive dance.
Dense, powerful muscles require a lot of energy. Gorillas and Chimps need a ton of calories, which often means a lot more time spent eating. If you're spending 16 hours a day foraging for food, how the hell are you going to develop society and culture and all those nice things.
High energy requirements also make things tough during lean times. It's postulated that part of the reason Humans out completed (and out fucked I guess) Neanderthals despite relatively similar intelligence levels is Humans needed less food to survive and were able to ride out the last Ice Age while Neanderthals starved (and got literally fucked into submission).
I'm sure there is other stuff, but that's what leaps to mind at the moment.
Not mutually exclusive (Neandetals were turbo built humanlike intelligence hominids) but it makes long term survivability and adaptability much tougher.
Reactions: lxskllr
[DHT]Osiris
17,563
16,921
We were probably more adapted to long distance running than our more bulky brethren, which would have permitted us a greater variety of game to hunt and larger areas to cover if food became scarce.
dank69
37,617
33,336
To beat up Godzilla, duh.
Mostly to beat up other gorillas to get dibs on the babes.
That's all I could think of as well, but that just doesn't seem like enough to me to explain why they evolved to be so strong.
DigDog
14,820
3,095
[science]
you are actually much stronger than a chimp; the determinig factor in how much of that strength you can use is the Pain Threshold, which is directly linked to instinct and aggression.
so yeah, being smart does preclude being strong.
[/science]
[DHT]Osiris
17,563
16,921
[science]
[/science]
Objectively false.
Feb 4, 2009
35,862
17,407
For example the chimp that literally tore a woman’s face off.
Could anyone in this threat pull someone’s face off?
DigDog
14,820
3,095
Objectively false.
did you read it?
Our results show that chimpanzee muscle exceeds human muscle in maximum dynamic force and power output by ∼1.35 times. This is primarily due to the chimpanzee’s higher fast-twitch fiber content, rather than exceptional maximum isometric force or maximum shortening velocities.
to be fair, i did ignore that we've had a evolutionary decline for something which isn't necessary (i.e. explosive strength) to simplify things, but a 100kg human raised by chimps would fucking obliterate a 40kg chimpazee.
19,219
When people lift weights, the golgi tendon organ is the sense organ that tells how much tension the muscle is exerting. If there is too much muscle tension the golgi tendon organ will inhibit the muscle from creating any force (via a reflex arc), thus protecting the you from injuring itself.
Interestingly, one of the ways of building strength is to override this protection mechanism:
[DHT]Osiris
17,563
16,921
did you read it?
Huh? Their muscles have a higher strength potential, and an average chimpanzee will far exceed the strength of an average human, even at the weight differences between them. It does not take that much force to break a neck or crush a skull, a chimpanzee can easily handle it.
You can't look at it as a math equation. You have to imagine this fucker trying to pull your arm out of its socket. You can hardly punch it into submission.
Feb 25, 2011
16,999
1,628
We're adapted for walking upright a lot. If you're top heavy you topple over. Our leg muscled are, relatively, better developed than most.
DAPUNISHER
32,451
33,466
Speak for yourself. :p
Evolutionary pressures change. Look how quickly humans adapted to living at high altitude. Becoming tool users and fire wielders played a big role in how we evolved.
BarkingGhostar
8,410
1,617
Brain Over Brawn. Like most species there will always be those that specialize down one path vs. another. It also helped that the genetic defect in humans resulted from the jaw muscle being severely reduced and allowed our brains to push out the skull. Cosmic ray mutated us into existence. The other primates were too stupid to complain, though.
Reactions: Ken g6
