Stochastic
- Apr 1, 2012
- 51
- 0
- 61
Since you mentioned owning lots of headsets, you might want to consider getting a desktop headphone DAC/amplifier such as this: http://www.amazon.com/FiiO-E10-USB-H.../dp/B005VO7LG6
I have an Asus Xonar Essence STX and a set of Sennheirers HD650s. I would never pair such headphones with on board sound. And I would never pair such a sound card with cheap ear buds. Together though? Worth it.
I would never pair HD650's with an ASUS card, or really any non professional PC card. At that point you are looking at External AMP/DAC territory.
Ummm, have you looked up the essence STX? It is quality card with a great dac and a good headphone amp.
I can do one better, I owned it in my last desktop.![]()
*removes foot from mouth*
You found it to be inadequate as a headphone amp?
For better headphones yeah, usually anything above $300-400 will improve with a nicer AMP/DAC then the ASUS card. For $50-200 cans it is a great card tho as a better AMP/DAC wont really bring much more out of that level of headphones, or it will bring some, but not enough to warrant the cost (as a good AMP/DAC can run you $800+)
These Logitech are ALL base and no mids, its a well known problem with pretty much all of Logitech's speaker lineups. I actually knock the bass down about 20% and its better, but that particular EQ setting brings the lost mid range back on this setup.
You guys are using upper end gear and enjoying it, but the majority of users have never heard a quality setup and their tin ears become accustomed to whatever sound quality their setup delivers. I work with a guy who has $2k tweeters installed in his kitchen ceiling, and Bang Olufsen and Carver gear throughout the house. I'd probably be stunned at the audio fidelity that system is capable of outputting.
