disappoint
Yes or no?
It is one of the aggregate states so it is very much definable,but you need a lot of molecules to measure it not just one.'Wetness' as a quality is more of a sensation restricted to neurological interpretation than a chemical property of any form of matter or energy.
A single molecule of water is hydrogen,hydro=water gen=birth ,it is the stuff that "gives birth" to water but is not water itself so it's not wet either.
I think you are confusing atoms and molecules.
Yup,partially,still a single molecule of H2O is gas, at best, and not liquid.
No. An object is wet if it contains (some particular amount of) water. For an object to contain something there must be a clear boundary between the object and its contents. Water alone can't contain itself.
Prepare to have your mind blown.
OP's question is meaningless, because wetness isn't a valid attribute at the scale of molecules. We might as well ask what color protons are.
, each the size of a grain of sand, are surrounded by a sandy silica coating
