Is a single molecule of water wet?
Ruptga
10,246
207
You should read that article you posted.
You seem to be implying I didn't, but I can't imagine why. Powdered water contains water, meeting his definition of wet, yet it is completely dry.
Man I Suck
170
Sorry, you are wrong again. Discussing somethings physical state is specifically describing the interraction between the different molecules. By definition one molecule of anything is neither solid lliquid or gas.
This. Wet is a function of or a perception of liquid which is a state of matter that requires a relationship between more than one molecules of said matter.
If it can't be defined as a liquid form then it can't be defined as wet.
Dittybob
Guest
Jun 23, 2015
10
Wet or dry is ascribed by the observer.
If the perceiver is sensitive enough to 'observe' a single water molecule, then perhaps ...yes.
DigDog
13,726
2,253
the question cannot be answered until a definition of *wet* is given. can 1 molecule of water penetrate your sweater and make it 1 molecule wetter than it was? yup. so 1 molecule of water is indeed wet, if that's your definition.
is it a liquid? as pointed out before, until it aggregates with other particles, it cannot be said, however one might speculate that "if it were to aggregate with other particles in a similar state" then, depending on the temperature of the first molecule, it could be *wet*.
we also use the name water in common language to identify H2O molecules in liquid state, calling the other states vapour and ice, so 1 molecule of water is "a molecule of water between 1 and 99 celsius", which is wet. Ice has the potential to be wet, and vapour is wet as well.
so .. pls define wet and then we can continue. (the answer is yes)
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
I'm no chemist, but I believe 'wetness' is a property of the relationship between water molecules, not a property of an individual water molecule.
smackababy
27,024
79
86
This is according to Google:
adjective
1.
covered or saturated with water or another liquid.
So, water can be wet, as water can be covered with water. However, a single molecule of water won't fit this definition.
Dittybob
Guest
Jun 23, 2015
10
"If a particle/molecule can not physically possess a given property, it cannot be in a state that requires that property."
Anna somebody
ex;
Ernie the water molecule lived happily within his large extended family in the liquid 'state' (just south of Michigan). However, a heated dispute, caused Ernie to drift away from his molecular family.
Now, completely alone (most likely somewhere out in the deserts of New Mexico), Ernie no longer has any interaction with his family members and is no longer considered a resident of the liquid state (however he may still attend family reunions on occasion).
Bock
319
So a case of sphere shaped water containers is wet huh? :awe:
28,689
What colour are protons?
Same color as their paired electrons. :) The energy of emitted photons is a shared property of the whole atom. The color changes depending on environment.
I'm developing a physical underpinning for Rachel Dolezal. :p
Moonbeam
73,150
6,317
Water exists in three states, solid liquid and gas. Only liquid water is wet. A single molecule of water is in vapor form, a gas. Gases are not wet. They are dry.
28,689
Not necessarily. A single molecule of water can be surrounded by other water molecules. It can be bonded to other molecules without losing it's "wateriness" through hydrogen bonding. It can be a warm "ice" coordinated with other water molecules on a substrate.
28,689
Is magma wet?
Most is. In fact, dewatering of crustal slabs undergoing subduction is thought to be the primary source of magma generation, at least at plate boundaries. The water driven out of the plunging plates lowers the melting point of the rocks above, fascilitating melting and upward migration of magmas.
Phoenix86
14,644
10
If I put a small drop of water on your pants are your pants wet? No. What about a glass of water? Yes.
What about a glass of water on a bale of hay? No.
"Wetness" is more about saturation. You need "enough" water to pass a threshold between "wet" and "dry". It's subjective.
Moonbeam
73,150
6,317
Wat? A single molecule of H2O surrounded by not bound to other molecules of H2O is water vapor, a gas. Gasses aren't wet. A molecule bound to others is either in liquid or solid form. H2O bound to H2O as a liquid is wet but not if in a solid state. Whatever you were saying doesn't change the facts.
Man I Suck
170
I learned something today! :awe:
IEC
14,436
5,410
Single molecule of water?
Only in a thought experiment.
Exophase
4,439
9
Okay, let me rephrase my post to describe a necessary but not sufficient condition instead:
"No. A wet object contains (some particular amount of) water. For an object to contain something there must be a clear boundary between the object and its contents. Water alone can't contain itself."
