Originally posted by: WildHorse
Originally posted by: Leros
Amazing. I googled drill press apartment and found this thread.
Amazing. I Googled brain dead incompetence at English (too not to) and found this thread.
Drill presses might well be the quietest power tool, not an issue in an apartment.
Girlfriend loud when pleasured is bigger issue in my experience.
I once had a wonderful beach apartment in undergrad college, directly on the beach, where the upper floor frequently sounded like they had a bowling alley. Never figured out what that sound was, but exactly like bowling pins falling.
My various girlfriends & I gave them back more than they dealt out. times over! Past days when I foolishly thought life was hard ($), before true heavy responsibilities - back then I had no clue, as most don't.
Ultimately, soon after I relocated to Huntington Beach, that special place BURNED DOWN!!!! How rare is that, that your apartment burned down? Well it did.
Later when I gre up I got tired of beach breaks like Huntington & Torrey Pines, and moved to rock reefs & rocky points. Heaven!
So what you're saying is that I should have sex while operating my drill press to cover up the sound?
Originally posted by: ironwing
Originally posted by: JDub02
so many more tools more valuable than a drill press. how about a mill?
I don't think I've ever lived in an apartment where the floors could take the weight of a mill.
Get an angle grinder and sheet of corrugated steel. Take a few swipes at it. When your neighbors kick your door in, offer getting a drill press as a compromise.
They make little tabletop mills. Lots of people are turning them into CNC mills.
http://www.embeddedtronics.com/micromill.html
Do want.
The harbor freight micro mill is about $300. A lot of people seem to be using it and claim its not too bad. A few hundred more bucks to convert it to CNC.
There are a few other micro mills of higher quality in the $500-700 price range. I think they're a bit larger too.
They also make micro-lathes.
Originally posted by: Skoorb
No, not too loud. In fact while you're at it why don't you install a miter saw, angle grinder, oil-less compressor.
Originally posted by: irishScott
Depends on what you're drilling and how long you'll be drilling it for. Whatever you're planning, I wouldn't do it at night.
Wood would obviously be quiet. I'm thinking mostly aluminum for now. I know its softer and I think its quiet, but I'm not 100% sure on that.
What about steel?
What about steel?
Steel is generally quieter to drill than aluminum. Aluminum can squeak and squeal.
Hmm. I guess I got that backwards. I thought I remembered aluminum being a lot like wood and steel being the squeaky one.
Poking something often does result in lots of squealing when lubricant is not used.![]()
You speak from experience? I've heard about what goes on on these cruise ships...![]()
I bet cruise ships have full wood/metal shops aboard. They probably have armed guards to keep the old coots out.
Originally posted by: PottedMeat
If your drill press is running loud, you're either using it incorrectly or it's fucked up.
no water beds or aquariums either?
