is a 25 ms lcd monitor good enough to...
CheesePoofs
3,163
Depends on the monitor. Some 25ms ones are great, some are terrible.
The only way to tell for sure is to see it or read a reliable review on it.
icyarrows
40
well, i looking for a monitor w/ tv tuner and component inputs. I can get one for ~600$ that is 25ms. WILL IT BE ACCEPTABLE? OR WILL IT BE HORRIBLE? (the ghosting)
imverygifted
1,368
it will be acceptable, you will probably notice ghosting- i think the dell 2001FP has component input and you can get that for around 600 bucks. its a 16ms monitor why not go with that?
Googer
12,576
7
Originally posted by: icyarrows
be played on w/ a ps2 and get acceptable pic quality and ghosting?
Stick with a crt, there are no ghosting Issues.
Tiamat
14,068
I have my mini ps2 playing through Dscaler on TV wonder PRO on a samsung 213T. This is 25ms. When I play on my secondary Samsung 712N there is noticeable less ghosting. However, I like the colors from my syncmaster 213T better. So, I take a lil blur and play on the 213T. RPGs show the most especially on FMVs. For example, if there is an FMV that shows a character falling into a hole and there are closeup shots, you will see the blur between his/her falling body and the environment - especially if the environment is white, or bright colored.
