If the Motherboard/CPU combo is what needs to be compared, then what should I expect from my BH7/2.4B setup? I'm currently at 168fsb 3.03ghz 1.55v(act) with temp of 46C idle/61-62C load. This is with a massive Zalman cnps7000-cu cooler! I even purchased an SLK-900, 92mm tornado package which got higher temps with fan a 5v, and 43C/59C with the Tornado fan in all of its ridiculous dustbuster glory on a 12v socket! With these numbers, the cooling vs. noise factor leaned FAR toward the Zalman which is back in use.
BTW at default speed and voltage the temps were 42 & 56! And yes these temps are with a proper application of AS3. I was worried for a while but as long as I ignore the temp, everything is fine. I have read that ABIT has a problem with their temp readings. Any thoughts?
