Originally posted by: error8
Originally posted by: QuixoticOne
x8 + x8 = great for XF if you choose that route.
I'll say --
512MB 4870 = not worth it due to your 19x12 resolution and shortage of VRAM.
1GB 4870 = good for your needs for almost any game in 19x12 at either max settings or at least playable settings with some compromises (crysis)
I really don't see why is 4870 1gb so much more, at 19x12 resolution, over the 4870 512 mb. Tests show only a marginal speed bump, but nothing spectacular that can justify the big price difference.
http://www.hardwarezone.com/ar...php?id=2684&cid=3&pg=8
The 1gb version is simply not worth it.
Agreed. If you really want 1GB of VRAM and don't want to spend $500 on a 4870X2, then the GTX 280 is the best buy, but it looks like you want to stick to ATI.
Here is some advice, the whole "buy one card now, then down the road buy another and xfire / SLI it" isn't the best advice IMO. By the time you decide it is time for an upgrade, there will be a much better single card option with more "must have" features and without the scaling issues.
IMO, only SLI / Xfire when you are going to buy both cards together, or within a very close time proximity.
This is based on first hand experience.
EDIT: Spelling
