suszterpatt
- Jun 17, 2005
- 927
- 1
- 81
Do a google search for the model number. 4 pages of hungarian sites (.hu) and one yugoslavian. Good luck though.
Originally posted by: suszterpatt
This is after reseating it once. First I applied AS5 as per the site's instructions (rice grain amount on the middle) and my load temps were in the 49-54 range (more often above 50 °C than not). I seem to be getting a stable 47-48 °C by spreading a thick-ish layer of AS5 on the CPU's heatspreader and leaving the HSF's surface alone. I may try again with slightly less sticky stuff, but (un)installing the XP-90 makes the bones in my fingers go to places where they aren't meant to be.
Good point everyone is assuming that by ambiant they mean MB temp.Originally posted by: alexXx
lower your case temp from 40(which i bet it is) to 30 and your idle temp will be 35
i guarantee it
XP-120 is incompatible with my mobo. :
Anyway, the CPU temp is 53 °C right now, so I'll probably reseat it again.
*prepares fingers*
Looks like some you guys missed this bit.Originally posted by: suszterpatt
I'm using an XP-90...![]()
