is 400k/sec good for my wireless?
p0lar
634
400kilobytes/second or 400kilobits/second?
If it is 802.11b, 400KB/s = 3.2mbit/s which is... on the low side of acceptable.
JackMDS
29,554
430
If your contract is for 2Mb/sec. service then it is superb.
If your contract is 4Mb/sec. Then 400KB/sec. is you should get.
If your contract is 6Mb/sec. it is a little slow.
If your contract is 10Mb/sec. it is BAD.
Optimizing the TCP/IP Stack - http://www.ezlan.net/Internet_Speed.html
CasioTech
7,145
9
i took one of those flash tests on dsl report and it wrote...
1432kbps/362kbps.... Is that good? my windows network thing says 54mbps. That's a load of bull huh?
kevnich2
2,465
8
Um, taking an online speed test measures your speed to the INTERNET. If your wireless is 54mb that's the speed that your computer is connected to the internal wireless network. Apples & Oranges as far as speed comparisons are concerned.
us3rnotfound
5,334
Wireless sucks for this reason. Everybody will tell you the speeds you SHOULD be getting, but you never really achieve them.
vorgusa
244
Try hooking up to your router with a wire and turning off your wireless. then run the online speed test again and see if you have the same speed you had when you were connected wirelessly. with my old wireless router I used to have 4-5mb/s with my new one I get 9-10 which matches up to my internet connection
spidey07
65,469
Sure you do. 20-22 Mbs is normal for 802.11G and I get that all the time.
But if you have other 2.4Ghz devices then you cannot achieve this performance due to interferrence. Depending on how much noise you have even 1 Mbs can be good. Wireless is slow.
