tweakboy
At 5ghz at 1.5v I hit 71C.
At 4.8ghz at 1.45v I hit 65C.
At 4.6ghz at 1.4v I hit 60C.
That is pretty nice temps...for HSF cooling...
Yikes, what are the water temps like at that point?
Wow, those are some fast CPUs. You're brave giving them that much voltage.
Yeah it turned out I wasn't 100% stable at those voltages, though. My chip actually seems like an average overclocker. I'm settling at 4.5ghz at 1.35v for now. My temps are still quite good.That is pretty nice temps...for HSF cooling...
Hey Balla, good question!
I thought about doing that for my GTX460 (since I had two application packs and only used one for my 2600k), but the application process and the curing process really looked to be super finicky and I decided I wasn't going to do it and risk destroying my 460.
Instead, I went the "pop the IHS off" route for my 460, and then used NT-H1 on the bare die. Worked great (10°C temperature improvement).
With this experience, I will always be popping the IHS off my video cards until such time that the IHS are welded on like Intel does theirs.
The problem with popping the lid is that I use a full cover block for both. It's milled to sit perfectly on the IHS/ram/vrms... If I removed the IHS there would be a gap and it wouldn't make contact.
I could sand down the parts that hit the ram/vrms but I dunno if that's the smartest thing to do nor do I think I'm capable of getting it flush enough not to affect the other parts :'(
Humm do you think it would be possible to downclock the 470's a bit, then use a fps limiter to adjust load on them to control the heat?
I assume I want to run them around 95C sustained for the burn in period correct?
I don't know if 95C is warm enough, and would just need more time, or if it really does need 98C, but what you propose is exactly how I would try and do this (if I were trying to do it) so, yeah, I think it'll work.
In my case I had to run my 2600K at TJmax 98C for about 30 minutes for the cure process to complete. So if you do it at 95C then it would presumably take a bit longer still.
I think 71c at 1.5v is actually kind of nice. I think if I had a SB I'd try that . . . along with the Intel insurance plan.
I wonder if they made that plan so they could gather data -- on our dime -- about what it takes to make their cpu's blow up?
71c is fine if your going to upgrade in 2 years or soo.
1.52V is definitely not safe for 24/7 use. Hell, even the often-touted 1.4V is only good if you don't want to lower your overclock in two years from having the chip.
I know mine can take 2.6V, at least momentarily that is.
I forget I was in offset mode, thought I was still in manual mode, so I plugged in what I thought was going to be a manual Vcc setting of 1.35V and it turned out to be an offset of +1.35V to the existing 1.25V value.
When I saw the Vcc reading of 2.6V I nearly fainted in a panic to turn off the PSU. But it doesn't seem to be any worse for the wear, no degradation to speak of at this time. But I'm sure I rapidly accelerated the demise of the CPU. If it dies in a year I'll know why.
That's incredible!...Kinda not really but in a way it is.
How did I answer post #62 with post #61?
I wouldn't have believed it, or even realized I was doing it, if it weren't for the fact I had my voltmeter plugged into the mobo and sitting right in front of me.
I thought for sure something would have gone pop at that voltage. But nothing is different, it OC's to the same levels (no loss in peak OC's) at the same voltages and same temps as before, all IBT tested.
It is NOT an experiment I'll be repeating though 😀
