J Jaap74 Member Jan 30, 2005 37 0 0 Mar 11, 2005 #1 What is most likely the cause when I am getting this blue screen when overclocking ? IRQL_NOT_LESS_OR_EQUAL At 230 FSB with my new RAM ?? Cheers
Appledrop Platinum Member Aug 25, 2004 2,340 0 0 Mar 11, 2005 #2 do you have working pci agp and sata locks?
K Kid Vicious Member Mar 6, 2005 90 0 0 Mar 11, 2005 #3 check ram compatibliliy with the mobo's manufacturer's suggested list.
J Jaap74 Member Jan 30, 2005 37 0 0 Mar 11, 2005 #4 yes hitting 60 degrees under load............Zalman Superflower........ will get the stop code next time.... crashed about 3 mins after starting up.....
J Jaap74 Member Jan 30, 2005 37 0 0 Mar 11, 2005 #5 I just noticed my motherboard - DFI LanParty 875P-T mobo - is not on this at : http://www.ocztechnology.com/support/motherboard/ How much of a problem is this ?
P PurdueRy Lifer Nov 12, 2004 13,837 4 0 Mar 11, 2005 #6 Ram pushed too far when I got that. I backed off my timings and all was good
Appledrop Platinum Member Aug 25, 2004 2,340 0 0 Mar 11, 2005 #7 well clearly a quick way to check if it is the ram is to run a memory divider to drop the ram speed....
M mparr1708 Senior member Jan 5, 2005 258 0 0 Mar 16, 2005 #10 Originally posted by: Jaap74 Please explain IRQ ?? Thanks Click to expand... IIRC interrupt request line. IRQs are what a piece of hardware is assigned so it can send interupt signals to the cpu
