- Feb 12, 2004
- 170
- 0
- 0
Ok my bro purchased an asus k9n-e deluxe which is a socket 754 nforce 3 250gb chipset and a AMD athlon 64 3400. These components work perfect however the iomega dvd writer model number : nd-1300a does not function with it. I have checked for firmware updates and found none, when I looked in the BIOS the device is detected properly. The dvd has power and works perfectly when installed on my computer. Other cd-rom drives work fine with the nforce 3 250gb... for some reason the Iomega dvd writer does not. I cannot figure out why. HELP.
