Originally posted by: Jeff7181
"Why didn't I put everything I had in it?!" the answer should be obvious as well: Because you didn't know.
That's one thing that prevents people from investing. The fact that nobody knows what's going to happen, but that's not entirely true. Technical indicators can tell you what has happened in the past and what is happening currently. Typically you can tell what's happening, and what will
probably happen.
That's the key point. Technical analysis can only tell you what is more likely, and even then sometimes it's no more likely than getting heads or tails from a coin. Provided that you have a slight statistical edge, a proper risk and money management strategy, and proper psychological discipline (or an automated system to remove your discretionary thoughts from the process) you can be profitable. My strategy has proven profitable even if I'm wrong more times than I'm right. If 4 out of 10 plays work
and your gainers are at least 3 times your losers all it takes is proper risk and money management to be profitable.
The question though is how much and when? How much will the stock increase and value, and how long will it take, and when will it go back down?
None of which you could ever know with any reasonable certainty. Granted, you can gauge the strength of a move
after it has started, but you'll never know when it will go back down. It's easy to look at a chart and say, "See, that incredible shooting star that followed a rally to resistance in the intermediate trend channel told me that there was a reversal leading to a correction and a return to support", but that's after it's happened. Technical indicators are great for what they suggest... indications. Use
actual price action to confirm the indications.
Granted, there are people that make money with predictions, but I don't personally know of any that do so consistently, and it's consistency that makes you profitable.
So far I've been investing mainly in funds because they're lower risk than stocks and they can provide some very good returns as Descartes pointed out with TREMX. Now I'm more comfortable using technical analysis, and more confident in my ability to read the charts, and I'm now investing in stocks, with decent success so far. I bought CHINA back at the beginning of January for 3.33 a share and got stopped out at the end of January at 3.95 a share for an 18% profit in about 3 weeks. I bought ADPT a week and a half ago at 5.75 per share and I still own it at 6.43 per share which is about a 12% gain in a week and a half. But I also bought HPOL at 5.55 per share at the end of January and got stopped out at 5.15 per share for about an 8% loss. Had I set my trailing stops better and given it time to come back after that short correction, I would have still owned that one and had an 8% profit right now.
Don't do that
🙂. It's easy to say, "See, had I held on I could have been profitable", but it's not so easy to say, "See, had I held on I would have lost more!" The reality is that you didn't know it would have recovered, and it's precisely this lack of certainty that leads people to hold the bag on companies like Enron! Protect your profits! Getting out was the right thing, and I am suggesting that you should have gotten out
a lot sooner. An 8% loss will absolutely kill your portfolio. Think of it this way: An 8% loss means you need 8% just to break even. I know that's obvious, but thinking of it that way puts a new light on the matter. You now need a 16% gain to see 8%.
So that's what I'm working on now... finding a good method of setting trailing stops. I'm using 10% right now by recommendation of my grandfather.
If you are investing in a long-term buy-and-hold strategy then 10% might be ok, but if you're trading then 10% will put you out of business very, very quick. I've had weeks many of my plays went against me, and so has any trader. If my stops were at 10% I'd be wiped out in a month. If you're holding for the long term (3+ years) then 10% is ok, but anything shorter and you should consider a trailing of no more than 5% if you are profitable.
All just my opinion of course.
