Internet problem ......HELP!!!!!
gipson73
9
Ok Hello there and thanks for looking at this post. Hopefully you can help.
Here it goes, my friend has a k7s5a motherboard that has a built-in lan device. I have tons of problems getting to web pages (have att broadbang high speed) I can try to get on MSN.com and it will not load. Try agian and will not load. Try for the forth time and wham it loads fast. I can not get to ameritrade.com,hp.com and all sorts of other web pages. I lowered my security settings and let in all cookies but it does not do a thing. I can get onto microsoft.com slow but download file at fast speeds. It seems that I can download files fast but I can not get to web pages. I called ATT and they suggested I get the 128BIT encyrption patch. Didn't work either. Anyone have a suggestion. Win98se was just clean installed last night to see if that was the problem. I am sure that the Network stack it set up correctly. Oh ya I put my LAN card in also(IntelPRO 10/100) and that didn't help either. Could it be the MOBO? I can't beleive it is a hardware problem. I would think it is in software or internet setting!!!
Zepper
18,998
In case you hadn't heard, there was an internet attack just after midnite eastern time on Sat morning. It exploited a flaw in MS database server and really put a load on the net. Some sites are still unavailable. Things are getting back up slowly. You can probably expect strangeness for the next few days.
. You can read about it on any of the security and virus web sites. There are also some threads about it in Off Topic here.
.bh.
