Originally posted by: dguy6789
Originally posted by: Modelworks
When you changed out the router did you change out the wall adapter too ?
Yes.
Absolutely everything physical in my home network has been replaced at least once.
Some thoughts of mine: Could I be under a DOS attack of some sort? A flood of connections? Electricity isn't the problem, my hardware isn't the problem. I did notice that my connection would drop more often if I was running a torrent. Could this mean anything? The router will still completely shut down and then come back on, even when on my brand new ups.
First step Modem directly at the direct input into the house and one computer directly on it., disconnected from phone, the inside network, or whatever else rides on the system in the house. If it does not work, then it is really the ISP responsibility to make it work under this condition. Right Now, it is easy to them to dismiss you because it is Not their responsibility to provide you with support for your network, and whatever hardware you choose to plug into it, If it does work well under such clean setting, then apologize to the ISP , and continuer from there.
