OK, so here I am to give some more explanation about the graph wildhagen so kindly posted here
Offcourse I did give this explanation on the GoT forum, but I know that most of you guys will have some difficulty understanding Dutch
This is what I did:
For all 3 teams I took the total blocks submitted in the past three weeks. Let's call it week 1, 2 and 3.
I compared the difference between week 1 and 2, and between week 2 and 3. This I averaged to get an estimated rate of growth.
For DPC this was 3.2% per week, for AT -1.9% per week and for /. +0.3% per week.
Offcourse you can question wether a 3 weeks history is enough to predict a 3 months future, but problem was that if I was to go further into the past I had to go way back to the beginning of June to correct the DPC's rate for MF6 (we started saving for this one around May/June somewhere). This would just take too much time, so I decided to take only the past 3 weeks.
I used weekly totals to calculate the rates to correct for weekly flushes from some of our keyservers, and to correct for weekend influences.
Also for these 3 weeks I calculated the number of blocks retired to each team; this proved that DPC gets 7 times as much blocks retired to compared to AT and /. However in the total calculation this should not be a big factor.
Anyway using these factors and the average blocksubmission of the last 3 weeks I started calculating day by day the estimated score.
I also mentioned on GoT that when I initially calculated without 7 oktober stats the results were quite different from when I added the 7 oktober results (DPC had a rather big score for a Saturday). A longer term history is therefor necessary to get more accurate results.
Anyway, because the picture came out so nice I decided to post it anyway, just as an incentive for our team to keep up this rate! Not knowing it would pop up on your forum.
Hopefully it will also be an incentive to you to prevent us from obtaining first place before the end of this year
Happy cracking!
