BoomerD
- Feb 26, 2006
- 66,405
- 14,798
- 146
I'd definitely recommend union over non-union. For the most part, (at least here in Kahleeforneeya) wages are better and benefits are far better.
IIRC, a journeyman electrician in the SF Bay area draws about $40-$45/hour. Not bad scratch.
Apprenticeships are the best way to learn the trade. You get paid to learn. Most of the "related training" such as class-time isn't paid, but that's a relatively small percentage of your program and is usually on Saturdays and/or Sundays.
Sure, you start at a low wage, (usually between 40 and 50% of journeyman scale) but you get raises of about 5% every 6 months. That adds up pretty quickly.
Working conditions can be bad, as much of the work can be outside, but most crews don't work in bad weather. IF they don't have an inside job they can go to, they go home. That can be a down side to any aspect of construction.
Since the OP really doesn't want to become a journeyman electrician, just "dabble in it on the side", then an apprenticeship probably isn't going to work for him.
Check your local community college. Many here in Kahleeforneeya offer some "building trades" classes including electrical. You might be able to pick up enough to get a contractor to give you a chance as a helper.
