A 16C bottleneck at stock is not fine in comparison with efficient heat transfer from solder, liquid pro, or similar. We'll have to agree to disagree. I don't think it's acceptable in such an expensive product to have such substandard thermal transfer.No it's not; not when it works fine at stock speeds. I don't think there's any reason to think Intel will change their mind on this esp since they are pushing the E line.
I don't think Indium is all that expensive in the context of an i7.I don't really think the answer to replacing expensive indium is more expensive indium.
AFAIK it's a bit backwards: a "hot" CPU will require a bit less voltage than a "cold" CPU to operate at the same frequency.A CPU that runs quite a bit cooler because of efficient thermal transfer can run faster due to lower voltage required within a given TDP so its stock performance should be better and it should require less cooling noise for the performance.
I would love to see some independent testing of that, considering the top end is higher than to best pure metal (Silver @ 429, Copper is ~400). Indium is 92W/mK and Gallium is 40.
It's also a lot more than it would cost to get a chip with proper heat transfer, if Intel would deign to sell us what we actually want.
Been done already & for sale awhile now..
Not to you, but to Intel it is. I have no idea how expensive these things are to make -- $30, $50; who knows -- but adding $5 to that is very significant.I don't think Indium is all that expensive in the context of an i7.
This still doesn't explain, even if your math is even close to correct, why there shouldn't be one quad i7 SKU for enthusiasts with proper heat transfer — especially since the substrate has now been thinned.Not to you, but to Intel it is. I have no idea how expensive these things are to make -- $30, $50; who knows -- but adding $5 to that is very significant.
You add that $5, and it gets multiplied everywhere through their price structure. E.g., your i7 now sells for $30 more.
I don't disagree with the desire for better heat transfer. I am not a fan of market segmentation, though, in its current state -- it's nice when you use it to adapt things and be creative, however it is just serving to make the lives of people with privilege better, at the cost of those without it.
It can have greater segmentation by having soldered i7s and polymer TIM i5s.Intel's job is to make money. Segmentation is great for business.
my cpu has 18c water into the block [25c room] and if that was not enough I'd mod the case to include a 120mm fan behind the cpu socket.
most peeps use a $ 30.00 cpu cooler they picked up on sale.
[and they want a cooler running cpu from intel for free maybe]
same with gpu's mine are idling at 20-21c [room at 24c] at max load never over 33c
I'd really like to know how you've broken the laws of physics by having your chips run cooler than ambient.
Check the poll results and the fact that quad i7s like Devil's Canyon were specifically called enthusiast parts — parts made for enthusiasts, designed to appeal to enthusiasts, and sold to enthusiasts.They call that HEDT...
Check the poll results and the fact that quad i7s like Devil's Canyon were specifically called enthusiast parts parts made for enthusiasts, designed to appeal to enthusiasts, and sold to enthusiasts.
Intel even came out with a PR campaign to tell everyone how it had improved the thermal transfer performance of its polymer TIM. Of course, according to one article I posted, that didn't happen.
The other problem with the "E" point is that they aren't available to buy so telling people to buy them instead is rather impractical for those who can't wait around. As long as Intel goes for long periods of time without releasing "E" chips with updated cores the "just get an E" point is further weakened.
I'm sure you guys can see the writing on the wall. It's not like I didn't vote for indium solder to be used on mainstream CPUs, but guess what, it's not going to happen. Enthusiasts who want to stay with the mainstream platform can delid, for those who don't want to do that or who need more cores, there's HEDT. Unless or until competition in the enthusiast desktop segment returns, that's the reality...
