Intel's TIM continues to create heat bottleneck, many years after Ivy
What is your opinion about Intel and TIM?
  • One i7 quad SKU should have Liquid Pro or solder transfer efficiency
  • All i7 CPUs should have Liquid Pro or solder transfer efficiency
  • All i5 or better CPUs should have Liquid Pro or solder transfer efficiency
  • I don’t mind a 16 - 20+ C bottleneck so I’m happy with how things are
  • I am not in the market for anything more than an i3 so I don’t care much
moonbogg
10,734
3,454
because some idiot is going to buy it crank down the heatsink crack it and complain on forums about how he got ripped off.
then he'll rma it and intel won't cover physical abuse and he'll complain even more.
so to skip all that they just won't not include one.
That idiot would probably be me I think. How can you install a water block/HSF without the IHS? It distributes the load, and even then I'm surprised that CPU's don't crack more often even with the IHS. A lot of force goes onto the IHS from the heat sink screws. Maybe its best that there is a HUGE ASS GAP between the IHS and CPU to protect it from much prevalent overtightening noobery.
III-V
678
Yeah right. The biggest cost cutting measure has been their lackluster research budget.
And that excuses this how, exactly? Quit shilling for Intel. The longer you and others stop holding them accountable, the more consumers get the shaft.
Rakehellion
12,181
35
What do you suggest? A boycott? Class action lawsuit? Good luck with all that.
VirtualLarry
56,587
10,227
Hopefully there will be a delidding i3 thread when those overclocking motherboards finally become available for under $100.
??? ASrock Z170 Pro4S ATX has been $80 several times, and even as low as $71-72. (I picked up a second one at that price.)
KaRLiToS
1,918
11
I'm against intel for doing the thermal paste crap. I would prefer paying a 15$ extra to have solder.
EK actually released a precise mount for bare die cooling...in 2013
http://www.bit-tech.net/hardware/cooling/2013/06/08/ek-supremacy-precisemount-review/1
Techhog
2,834
Rather than argue about TIM. It should be about why they dont sell an already delidded SKU. If you worry about temperatures you wont have the IHS on in the first place, solder or not.
This would be awesome, but you can't really blame Intel for not wanting to risk it. What I don't get is why no OEM or even mobo manufacturer wants to offer an option like this. Is there anything stopping MSI from offering a motherboard + delidded CPU + delid guard combo?
ShintaiDK
20,378
RMA rates? ;)
dark zero
2,655
140
A boycott is good and informing massively to the people in order to make them avoid to buy laptops with U trash or Atom based chips and going to the real deal, the H tier.
ShintaiDK
20,378
AMD went TIM for the same reason as Intel on its APUs. I can almost guarantee that Zen for example is TIM based too.
ShintaiDK
20,378
Is there a way to find out which AMD CPUs are TIM based?
All but the AM3+ FX series it seems. So all FMx. Tho it seems that there is conflicting data if 7850K and 7870K is solder or TIM.
750K for example:
7700K
Ken g6
Moderator
Dec 11, 1999
16,806
4,789
75
Thread seems to be gone. But that led me to another thread about delidding, which points out something interesting. Apparently, many single and dual-core chips older than Ivy had TIM. Including several Core 2 Duos. (They're listed in the "What to practice on" section.)
So if TIM has been there that long, why are people only complaining about it now? :confused:
MrTeal
3,919
2,708
It's not terribly difficult if you're careful. Apply your TIM, then set your block down on the die flat. Take the slack out of the screws, and then just start tightening them a bit at a time crossing back and forth. As long as you don't plop it down and then tighten one screw the whole way so all the force is on the one corner you should be fine.
KaRLiToS
1,918
11
The thread is still there, and by the way, it is the same poster has the one here. Except it is more heated at OCN.
hawtdawg
1,223
7
The TIM isn't the issue, the gap between the IHS and the core has always been the issue.
III-V
678
It'll still take a couple of years before we start seeing the biggest payoffs of those investments. Looking forward to it, though.
Heck, this year is pretty damn exciting. Potential Zen launch at year's end, new graphics cards... Kaby Lake might actually not be the letdown that Skylake was for me.
Good thing I'll have my own tech website up and running in maybe a month's time :)
