Either Geekbench is screwed up, or Intel really screwed up and underestimated the competition with Silvermont, especially on floating point.
Wouldn't doubt either at this point; smells a lot like Bulldozer at this point, but I hope I'm wrong and that Intel isn't foolish enough to put out an incredibly weak processor when it needs leadership just to break into this new industry.
Definitely wouldn't read a lot into the FP scores. I was already mostly ignoring those for ages.. like you showed, they're suspicious against other platforms too. And it's not just a subset of tests. Even if they're legitimate they're pretty micro-benchy and they're not being compiled to very good code.
The integer code is more representative (but not of everything, not even close!) because it runs actual libraries and VMs that are in use. But even that relies on the input data set being a good representation. I have my doubts about the program they're using for the Lua test..
But despite all of this geekbench is
still one of the best mobile benchmarks in use
Here's hoping version 3 is a good update.
Anyway, the numbers for the integer part aren't bad at all. perf/MHz may be a little lower than A15 in some cases (although it's higher in others!) but that's not at all a bad position to be in if they're really using substantially less power while clocking even higher. Let's take a massive leap and say the integer part really is representative of performance across the board - if they can take this and hit 2GHz at ~750mW/core or less then they'll be in a very strong position. And there are some people who think the power consumption will be even lower than that; this I will need to see for myself.
I think what could end up holding Intel back the most is not the broad engineering side of things but the area constraints they're working in. They'll probably be spending a lot less die area on GPU than some of their competitors (at least Qualcomm and most likely Apple) and I suspect they'll be paying for it. There's also the matter of using only 2 cores in their phone parts when a lot of their competitors will be using 4.
