Athlon4all
- Jun 18, 2001
- 5,416
- 0
- 76
<< Easy for you to say if you don't have to deal with increasingly difficult signaling issues. DDR is a dead end. My friends and profs in EE all say that crosstalk, interference, and other physical issues are hindering parallel busses. While CPU speeds increased from 500 - 1000 - 1500 MHz, SDRAMs went from 100 to 133 and 266 MHz. It's very hard to make current SDRAMs run as fast as they do. >>
Well said! We may keep on hearing the possibility of DDR above 333MHz but, the truth is that DDR is really on it's last legs. I predict that the last SDRAM technology speed increase is going to be that to 166MHz, beyond that, I doubt there will ever be SDRAM devices that are having good enough yields to ever appear on the Retail market.
<< Last time I checked PC800 RDRAM prices are on par with DDR prices.
They are. People need to get up to date and realize that DDR and PC800 are on equal grounds!!
<< Everything is a dead end, what's important is what will hold until something new comes out. RDdram's supposed technical superiority should have been suspect the moment P4 launched with the need for 2 sticks of RDdram. >>
What's that supposed to mean? The 850's need for 2 RIMM's at a time, has nothing to do with RDRAM technology. It has to do with the fact that 850 (along with i840, nVidia's nForce (that's right, a DDR platform needs 2 DIMM's:Q and the new Intel E7500 (another DDR platform that needs 2 DIMM's!). You know why? Because all of these platforms use dual channel memory controllers. I will also add that if you read Anand's 2nd IDF report, there is upcoming 32-bit RIMM's that with proper motherboard implementation, will allow you to use only 1 RIMM at a time.
<< And, we've all seen the benches at aces right? with the pc1066... >>
Not to mention the more recent THG benchys as well.
<< DDR-II is vaporware at this point. >>
It's in development lets put it that way, but it's still a few years off. There are really only 2 ways that DDR bandwidth will increase over the next few years, and they are QBM (which basically turns DDR into QDR (Quad Date Rate), and there was some suypport from it (partitcularly VIA who was going to implement it in P4X333 but has removed it from p4X333) but it's life seems to be up in the air at the moment.) and Dual Channel DDR, which I feel will be more expensive that a similar 850+PC1066 platform. I won't get into why, but IMHO RDRAM will all of a sudden become the "value" market. We'll see soon by juding the performance and prices of intel E7500 boards because it's that chipset's memory controller that will end up in Garniet Bay (Intel's Desktop DC DDR chipset).
