Intel processors crashing Unreal engine games (and others)
BFG10K
22,709
3,007
As if we needed any more evidence that these Intel furnace monstrosities are being pushed beyond their limit just to win performance benchmarks. No wonder even 480mm rads or 1.5kg coolers aren't enough for these solar flares.
These parts are being redlined because they're horrifically inferior to AMD X3D processors for gaming, and yet there are still some people on the internet defending Intel's version of Bulldozer.
This is the result of an absolutely incompetent monopoly that sat on 14nm+++ for seven years and was happy to keep selling you +5% performance + new motherboard every 18 months.
Dave3000
1,546
114
What are the chances that setting to XMP in the BIOS can play a big part on this instability? Afterall, XMP is considered a form of overclocking as in it runs the memory at speeds faster than what the CPU officially supports, and I wouldn't be surpised if there are people who build their own systems and don't pay attention to what the memory controller on the CPU actually supports and just buy the fastest memory they can afford and that motherboard they buy supports and then set to XMP in the BIOS to get their memory to run at it's advertised speed, even if they don't have the intention of overclocking. Also I used to own a motherboard that if I enabled XMP, it would overclock the all-core turbo speed to it's single-core turbo speed for all core loads.
Markfw
May 16, 2002
27,376
16,217
This is not explicitly Intel fault. Is simply than Motherboards vendors leave unlimited Power Limits or MCE (MultiCore Enhancement) on by default, so you are overclocking out-of-the-box without knowing it.
I don't think most vendors (if any) leave this on by default. Intel experts chime in here ?
Apparantly tomshardware says SOME (but does not say who, or how many) do set this to 4096 watts and 4096 amps, but I find it hard to believe that many would do something so insane.
jpiniero
17,097
7,486
Unlimited power limits shouldn't cause it to crash. MCE might... but that would mean you got a dud that can't do ACT stably enough on all of the P cores.
H433x0n
1,224
1,606
If you enable XMP you’ve inadvertently enabled MCE for the popular motherboards. This setting means unlimited current and uncapped power limits.
tamz_msc
3,865
3,730
Holy hyperbole!
tamz_msc
3,865
3,730
Most, if not all Intel motherboards have some performance enhancing settings turned on by default.
This has been a problem since the days of Coffee Lake.
Intel just needs to stop allowing concessions to OEMs that are used by them to exploit loopholes in the specifications.
gdansk
4,714
7,978
Much ado about numerous vendors shipping their motherboards with bad defaults is not nothing.
Most the people reporting the issue had no idea they were overclocked. Intel can and should put the kibosh on vendors shipping firmware like this.
tamz_msc
3,865
3,730
This has been going on for 7 years at least. It was first observed with 8th gen Coffee Lake. Only it wasn't a problem back then probably because 14nm++ is more tolerant of transients than Intel 7.
IEC
14,606
6,094
I set PL1 and PL2 to 105W on my Z690 rig just for efficiency sake, but I had no idea ICC_max was even a configurable setting.
Once you have to change out of the box settings you're already past 90% of users, whether Intel or AMD...
Saylick
4,106
9,598
Yeah, if enthusiasts dont even know about how to fix this issue, average Joe would not stand a chance.
BFG10K
22,709
3,007
As expected, the culprit is ICC_max set to above spec - it should be 307 A for the 14900K.
ICC_max is more important than the PL1/PL2 values.
I'd never heard of this setting until now and had to look it up. I know how to write a double-linked list in C using free() and malloc(). I bet most people in this forum can't do that, so I'm not a computer illiterate moron by any stretch of the imagination.
A lot of tech enthusiasts don't even know about XMP or how to set a high refresh rate,, much less something as obscure as ICC_max.
Much ado about nothing.
Then it should be absolutely no problem for Intel to proactively contact all major CPU reviewers and ask them to retest @ spec. Amirite?
tamz_msc
3,865
3,730
And I absolutely detest writing computer programs (I find it terribly boring - I'd rather do a math problem), and yet I know about ICC_max.
Yes, obviously.
Then the conclusion of Intel CPUs guzzling power would magically disappear, which will then go against the prevalent narrative.
BFG10K
22,709
3,007
Nobody cares what you find boring because it's irrelevant.
The performance will magically disappear too, that's why Intel happily look the other way when benchmarks are posted.
And it's not really a narrative, more like objective proof. 14900K overall slower than X3D for gaming while absolutely chewing through power. Also throttles @ stock even with a 360mm AIO liquid cooler.
coercitiv
7,449
17,763
I can't feel properly vindicated about this because I know it must have been very painful for people to figure out why these systems were unstable (both users and game devs). Still, it does feel nice to finally have public proof that all this irresponsible board maker behavior is toxic for the consumer. Also, the biggest irony is the folks affected are the ones buying the premium hardware.
Like @zir_blazer said, this is not explicitly Intel's fault. Still, they were complicit. Now they'll pay the PR price.
coercitiv
7,449
17,763
Here's how it happens on my MSI Z690 board. Any time I make a change that affects my CPU multiplier or enable XMP, I get this pop-up message in UEFI. You'll notice there is no Cancel button. MSI decided that consumers don't need Cancel buttons, that would only confuse them. And just in case someone tries to say "but", one gets this prompt even if they try to underclock, lower CPU frequency below stock.
So what is Water Cooler setting?! Well, I'm SO GLAD you asked! Let me introduce you to the Power Menu à la carte:
Current limits:
  • Boxed Cooler 240A
  • Water Cooler 512A
I would expect that most boards with Z chipsets and most B/H chipset "gaming" boards with powerful VRM stages will exhibit this behavior. The more expensive the board, the more likely it will behave like this. For the example above, mine was one of the cheaper Z690 models and still does it. In other words, all the boards that one would buy together with a 13900K or 14900K will fit the profile.
tamz_msc
3,865
3,730
Nobody cares if you are a coding wizard either, it's irrelevant as well. But this is a forums for PC hardware enthusiasts, and it reflects poorly on those who flaunt the tag 'enthusiast' if they don't know about the basic things they ought to know about their hobby.
They perform practically the same if you remove the outlier reviews like Techspot/HWUB (which favour AMD) and some other reviews by various European outlets which favour Intel.
The only difference is the power consumption while gaming - and yes, this thread is about why that is the case.
BFG10K
22,709
3,007
Nah, it's very much relevant. Someone that builds PCs and codes in C has vastly more knowledge than the average PC user. If you're seriously suggesting all 14900K owners should know ICC_max is intentionally out of spec and causes issues, your argument is pure delusion at its finest.
Your first two posts didn't even mention ICC_max. You obviously furiously ran some google searches after and then posted a follow-up how it's "obviously expected" to be the cause. Oh, you tech searcher, you.
"Outliers", because they don't fit the Intel apologist(tm) handbook. Intel could enforce these limits on reviewers and board makers (including mandating PL1/PL2), but they don't. Hmm, what could Intel possibly gain by allowing their hardware to run out of spec for internet benchmarks? o_O
And...I wonder... is it the same idea that was behind their SPEC cheating?
Or how about this one?
Thunder 57
4,244
7,038
Yes, obviously.
And so would their performance. Intel gets creamed at lower wattages.
