Intel Pentium III M 1.13Ghz Mobile Processor skt 478 now for $14.99
tamasrepus
82
The only machine I have I think this CPU would work with has it's original CPU soldered in. I'm going to assume it's similar for a lot of other notebooks based around this CPU.
Zap
22,377
7
I believe they used a socket 478 similar to the Pentium M because it was physically smaller. Note that the Intel site states it runs on a 133MHz FSB, not the 400/533MHz of a Pentium M. This CPU will not work in any desktop board.
bearxor
6,605
Originally posted by: labgeek
hadn't noticed he said 3... saw the 478 and assumed. thought about picking one up too... glad I didn't.
Yea, uh-huh... next time you'll read it all the way through before trying to pick a fight :D
Trust me, if it was a 1.13ghz PentiumM (if one existed to begin with), I would have snapped one up too.
Zap is also correct, as I don't believe there was a single desktop motherboard made that supported the 478-pin Pentium 3. Do note, however, that a LOT of last generation Pentium 3 notebooks used this socket, including a lot of Dell's. If you're in doubt and you have a Pentium 3 notebook, simply download CPU-z and it should let you know what socket you're using.
Hacp
13,923
Also, depends on the motherboard. Some mobos only support up to a certain clock speed.
fr
6,408
Yep. This chip is physically smaller than a CompactFlash card.
codeyf
11,854
Originally posted by: pxc
Why would anyone assume a Mobile P3 would work on a P4 board? That's pretty silly.
FINALLLY, someone pointed out the obvious! Moreso, why would you want to use a P3 in a P4 board????
/thread
mscdex0
2,868
Why would they have 2 different versions of a socket type? (478)
That's pretty silly. ;)
Zap
22,377
7
I think people were thinking it was a Pentium M - somehow their eyes were glazing past the "III" part. The Pentium M chips (perhaps excepting the ULV models) can work in certain Asus motherboards with an adaptor, giving a P4 platform Athlon 64-like performance.
Zap
22,377
7
Originally posted by: Flatbroke
Mobile adaptor
Yup, that's to adapt the {b]Pentium M/Celeron M[/b] to certain Asus motherboards. However, the CPU listed by the OP is a Pentium III M. Even if it used the same physical socket (I'm not sure on this) the electrical characteristics would be different (I'm sure on this).
LostWanderer
306
Originally posted by: bearxor
NO! Do not put this processor in a S478 Pentium4 motherboard.
Bad geeks, BAD!!!
http://www.tomshardware.com/cpu/20050525/
Summary:
With a simple adapter, Intel's Pentium M processor can be used on veteran mainboards based on the i865 and i875 chipsets.
Would you believe that this unorthodox combination proves to be so fast that it beats even the Athlon 64 FX and the Pentium 4 Extreme Edition?!
And if I remember right, I thought there were mods that let you skip the adapter on some motherboards too... hmm
bad bearxor... bad...
Notice the highlighted part, did no one else catch that? Pretty funny.
Borg20001
631
Hey, I'm a neophyte when it comes to upgrading laptops, and only marginally experienced in upgrading desktops.
Here's an easy question. I have an oooold Compaq Armada 1592dmt. Can this system use this PIII cpu? Or is it just too old (as I suspect).
Thanks for a slightly off-topic question.
tcsenter
18,933
566
There was a discussion about this awhile ago, but I can't find it in the archives. Anyhoo...
Processor Compatibility Issues
The new Intel® Pentium® 4 processor uses a 478-pin package while the mobile Pentium III processor in the FC-PGA package uses a 478-pin package. While physically, you can insert a Pentium 4 processor into a mobile Pentium III processor-M laptop or a mobile Intel Celeron® processor notebook and you can insert a mobile Pentium III processor-M or a mobile Intel Celeron processor based on .13 micron process technology into a desktop Pentium 4 processor system, the two type of processors are not electrically compatible and it will damage the processors and/or the system if you do. In addition, this can void your warranty for your laptop and processor.
The PIII-M processor is a PIII architecture used with Intel 815M and 830M mobile chipsets, NOT P4 architecture.
zikronix
1,324
Originally posted by: rchiu
Originally posted by: dugweb
:Q I have an IBM T21... pentium III 800mhz. I really don't have any clue, would this new processor work for it?
I have T21 too, why don't u try it and let me know. :) But seriously, T21 runs at 100 FSB and this runs at 133, so I don't think it will work.
First of read this regarding the p4/p3 thing directly from intel.
http://support.intel.com/support/processors/mobile/pentiumiii/sb/CS-007528.htm
then
I have one of these too...IBM also says it wont take pc133 memory but guess what the 512 of pc133 i got in mine works fine. Ibm says the fastes processr this thing will take is a 900. However for 20.00 im in and ill try it. and if not it goes on ebay for 40.00
lol
EDIT: NM I found this....AWESOME
http://groups.google.com/group/ibm.ibmp...6cb78f36?sa=X&oi=groupsr&start=0&num=3
And then theres this to actully help you find the processor
http://processorfinder.intel.com/script...kgType=ALL&btnFOS=Filter+on+selections
it looks like thes are our winners here
http://processorfinder.intel.com/script...5&PkgType=ALL&SysBusSpd=ALL&CorSpd=ALL
which you can grab here
http://search.ebay.com/SL53S_W0QQfromZR40
this model number too
SL53S
SL5TF
SL58S
and I think these too
SL54F
SL5TB
back to the thread
dugweb
3,935
then
lol
SL53S
SL5TF
SL58S
SL54F
SL5TB
back to the thread
thanks :p nice going lots of good info, exactly what I needed
tcsenter
18,933
566
As noted in the Google Groups thread...
"T20/21/22 in that they MAX out with BGA2 1GHz PIIIs and
they're all built on the same Intel 440BX chipset."
"The T23 is built on the Intel 830MP chipset and has the Micro-FCPGA
processor. The fastest Micro-FCPGA PIIIM is the 1.2GHz"
The T20/21/22 are based on mobile Intel 440BX chipset and are Socket 370. T23 is based on Intel 830MP and is Socket 478.
This processor won't work in T20 ~ T22, but will work in T23.
DJMiX
1,603
Originally posted by: manno
these may be 478, but I doubt you cna plug a p3 478, into a p4 478 motherboard. If anyone can tell otherwise, please post. Otherwise if you're buying this to plug into a P4 mobo, don't, you'll probably ruin one, the other, or possibly both.
P3 run on FSB 100 MHZ, no way this will run on a 400MHZ base FSB boards ...
NO NO to Mobile P3 on a P4 board
Funyuns101
2,849
anyone know if i can replace a 750 mhz p3-m for this one in a toshiba portege 2000?
tcsenter
18,933
566
Try Toshiba's toll-free support line for computer related products: (800) 457-7777
