richierich1212
- Jul 5, 2002
- 2,741
- 360
- 126
The GTX760 is available for $799 on Newegg & Amazon: (p/n GB-BXi5G-760)
Amazing.
Newegg has the i3 Haswell NUC with mSATA only (no 2.5") for $217 shipped.
Pretty awesome deal: Intel NUC Kit D34010WYK1
http://www.newegg.com/Product/Produc...-053-_-Product
I have the 2.5" version and it does just what I need with it as a STB/DVR replacement after some initial problems with Intel drivers. Streams HD Video from Amazon Prime/Netflix/HBOGo etc. with no problem, but also works perfectly for live HD playback of encrypted premium cablecard content from my HDHomeRun Prime through Windows Media Center (most important feature for me).
Overall plenty fast with a 240GB Crucial M500 mSATA, but I don't use it for anything more intensive like gaming or work. If I hadn't already bought the 2.5" version I'd definitely get this one instead since I already have my WMC live TV recording to my NAS on a 2TB share via iSCSI target.
I have both a Logitech K400 for PC/desktop mode and a cheap Windows Remote for input like a TV while in WMC.
How did you fix your intel driver issues? I'm still having problems with my 4th gen NUC
Zotac has a new NUC competitor called the ZBOX Sphere:
http://www.anandtech.com/show/8303/zbox-sphere-oi520-plus-zotacs-take-on-the-nuc
Looks just like the Nexus Q. I like the rear port design:
http://images.anandtech.com/galleries/3812/DSCN8525_575px.JPG
The analog speaker output is on the rear (can't tell you how much it annoys me having it on the front of the BRIX), it has a built-in card reader, and it has two extra USB 2.0 ports in addition to the four USB 3.0 ports.
I actually might pick one of these up next weekend - i'm looking at intel and gigabyte 2.5 i3 models; has anyone used both and if so any comments/comparisions ? I know the gigabyte comes with a weak wifi card and tends to be a little (?$20?$30?) cheaper. I definitely want the 2.5 model since I have an old ssd I can use and that would save me the expense of a msata storage.
No difference in noise or heat ? I lean towards the gigabyte because it is cheaper and has full size hdmi; but I think someone said it had more noise and the warranty is shorter (1 yr vs 3 yr). Btw I picked up a chromebox for $139 ($169 - $10 rebate - $20 gift card) for a relative web brower/mail. Took a while to get it into developer mode to install linux but other than that was very simple setup. Only reason I don't get myself one is that I need more than 16GB system disk and I have a bunch of 2.5 sata ssd lying around that I can use a 2.5 nuc.
250GB Samsung 840EVO mSATA on sale at Newegg for $121 shipped with promo code.
http://forums.anandtech.com/showthread.php?p=36634880#post36634880
250/256GB is the smallest I work with now...once you install Windows updates, apps, do formatting on the disk, etc. it really kills your free space on the smaller 120GB drive. That's not a big deal on a desktop, where you can just pop in an extra data drive inside the case, but on the NUC, you have to go external (or NAS).
I'm amazed that the 1TB mSATA SSD's are under $500...just wish I had more dough to play with![]()
Heh yep same, 240-256GB is enough for the OS, a few games, most applications you would need and a decent amount of personal files as well. I have a 240GB M500 mSATA in my NUC and its plenty.250/256GB is the smallest I work with now...once you install Windows updates, apps, do formatting on the disk, etc. it really kills your free space on the smaller 120GB drive. That's not a big deal on a desktop, where you can just pop in an extra data drive inside the case, but on the NUC, you have to go external (or NAS).
Linux does have a small footprint, but if all you needed was a browser/mail client, chances are you wouldn't need a NUC. For me, I have plenty of devices that handle lightweight browsing just fine, but Windows is a requirement for me for premium CableCard content.Pit you are not a linux guy; linux does ok with 7GB (I have it on the chromebox with the bundled 16GB drive) if all you want is browser/mail you can put video on sd card and plug it in the sd slot. on 64 or 120 GB drive linux is set for life as long as you don't have a large video library. Intel/gigabyte really should throw in the extra 30 cent sd slot.
Still no non-WMC programs able to handle this thus far afaik, Android and Linux options can do the OTA and non-encrypted content but still can't do the encrypted and premium CableCard streams last I checked.
I haven't used one, but I've always thought the best solution to the CableCard issue was to use an independent network decoder such as the SiliconDust HDHomeRun. I would get one if I didn't use a TiVo for all my cable needs.
Yeah sorry if I wasn't more clear, I am actually using a Silicon Dust HD HomeRun Prime as the decoder for the CableCard content and WMC is really the only viable solution for playback of the encrypted premium channels like HBO etc.I haven't used one, but I've always thought the best solution to the CableCard issue was to use an independent network decoder such as the SiliconDust HDHomeRun. I would get one if I didn't use a TiVo for all my cable needs.
There's a few other makers of CableCard decoders, like Ceton (they have 4 and 6 tuner boxes) and Hauppage (I think they just license SiliconDust IP though), but none of them are perfect. I generally see reviews indicating the SD is the most hassle-free unit out there, but it can be a frustrating process to set up the first time through. The SD forums are great though, have some really knowledgeable folks and FAQs set up to help new users out.I know this is slightly off topic; but I've been thinking of switching from cable box to HDHomeRun prime; and wanted to ask if there is an alternative to the HDHomeRun prime. I mostly run linux but I do have a windows 7 box that I can use for testing/setup. I do NOT subscribe to premium channels (hbo, ...) and unfortunately the only provider in my area is comcast.
