Page 784 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
alcoholbob
6,390
469
I can't imagine NVL latency is going to be any good with a dual CCD problems...if anything I imagine it's going to be as bad for gaming as Arrow Lake and Raptor Lake remains the gaming champ for Intel well into 2027-2028. 52 cores screams going all-in on all-core synthetic benchmarks and losing at everything else.
Reactions: Joe NYC
Thunder 57
4,250
7,047
As I wrote, not in all workloads. And different workloads will benefit more from it than others. But over time, more applications will be adapted to make better use of more cores, the more cores are commonly available.
We’ve already seen this trend over a long time. Compare the applications and games from 10+ years to what we have today and see how much they have improved in this regard already.
There”s really not many other options than to increase performance via increased core count currently, since we’re not getting much perf increase from IPC or frequency increase anymore.
As has been said, Amdahl's Law.
Reactions: Joe NYC
511
5,382
4,792
They just need to re design the fabric
Reactions: OneEng2
511
5,382
4,792
And DDR5-12000 CUDIMMS probably...just to get close to Raptor Lake
bruh like i have said before the packing they use is similar to Hopper so packing is not the bottleneck the fabric is and L3 as well i don't think Intel's Designers are so dumb and as fir DDR5 CUDIMMS at 12K that's going to be OC only.
msj10
112
118
You just need to look at Lunar Lake to get an idea about NVL memory latency. It's not that hard to figure out.
511
5,382
4,792
LNL is monolithic lol the PCH is combined using foveros that's it PTL you can call chiplet
msj10
112
118
NVL will be based on the LNL soc architecture. Intel even said the architecture can support multiple compute dies in the coming generations. they were obviously referring to NVL.
Reactions: 511
OneEng2
981
1,189
I think it is likely a bit more complex than that. I think the cores themselves need to be architected in a way that reduces the impact of off-chip latency on the processor performance. I do agree with your assessment that it is highly likely that the fabric will also be improved to lower the actual latency as well. This is easily the lowest hanging fruit as the core re-architecture will certainly be harder to achieve.
Reactions: 511
511
5,382
4,792
Btw does there exist a copilot hate thread cause what I am hearing is MSFT being ridiculous.
Requiring 80TOPS NPU
inquiss
625
886
As has been said, exactly the same thing that was mentioned by some during the 4C-forever phase. We passed that, and we will pass the 16C-forever phase too.
We're barely in the 16c phase. Most people want 8c or less. And the point of the law is you get diminishing benefits for the increased number of cores, so the position is different from 4 to 8 and then 8 to 16 and less benefit going up after that.
I'm not saying you're wrong over the long run, but honestly consumer doesn't need more cores. They need faster cores and bigger caches.
Fjodor2001
4,574
730
Consumer CPUs have maxed out at 16C (or 24C for Intel) for several years, same as when we were stuck at 4C for several years.
In the 4C-forever era it was said by some that nobody needed or wanted more than 4C, and it would be pointless due to Amdahl’s law, so no point providing more than that to the consumer. Then AMD proved that to be wrong, and introduced 8C and soon after 16C CPUs. They did so to break the Intel lead at that time.
This time it’s AMD that is in the lead, but stubbornly stuck at 16C. The exact same arguments are mentioned by the ST perf is all that matters crowd. And I think this time the tables will turn so it’ll be Intel that bumps core count to prove them wrong. Rumors say it’ll be to 52C, although with a mix of P/E/LPE cores.
There really is not many other options to substantialy increase perf than via core count increase, since IPC and frequency increase are only improving perf by a measly ~5-7% per CPU generation currently.
MS_AT
930
1,848
Sure, get proper GPU slicing and host game streaming for your whole family to their mobile devices. This will scale plenty with cores, and if you run into scaling limit, make the family bigger. This way we can scale quite well, depending of course on how many relatives you are willing to deal with, and it might be the house starts to become limitation faster than the cores, but well, one problem at at time;)
inquiss
625
886
How many people buy 16c products. The market is small compared to mainstream.
On your second point, you get more from going from 4 to 8 than 8 to 16. There's mainly for people with embarrassingly parallel workloads, not common workloads. What's the more common core count sold today? It's not 16. It's been 6, and maybe recently 8 and only because the x3D chips have 8.
Intel could release the rumoured 52c product. Doesn't mean it will be popular. It won't be. I expect that to be cancelled, though your mileage might vary. If you only run cinebench it might be good at that.
The x3D chips show that cache and speed matter more. You'll get more than 16 cores from AMD in the next platform..it's convenient to do so when reusing server designs. But bumping it up massively for client? Massive meh
Fjodor2001
4,574
730
Again, same aguments as during the 4C-forever area, when it was said that there was no point in going beyond 4C.
reb0rn
320
120
As soon 16 core is cheap and mainstream price they will buy it, while some % will want 32-64 core parts........ its just most ppl just can not see the reality of being stuck in time
Fjodor2001
4,574
730
How do you intend to improve perf substantially if not via core count increase?
Are you satisfied with 5-7% perf increase via IPC/frequency per CPU generation?
inquiss
625
886
Architecture, clock speed, cache size and cache structure, packaging, new instructions, IPC. Loads of options.
No, but I don't get why you think core counts are the only way to achieve something greater than 5-7% per increase per generation.
Hitman928
6,753
12,492
I don't remember many people making this argument at the time outside of maybe some Intel supporters who didn't want any criticism against their favorite company. That's not the situation today. Additionally, as soon as a viable 6+ core option was given, it sold extremely well. We have 16+ core SKUs today that don't sell all that well relative to their lower core contemporaries and in many instances they aren't sold because they have 16+ cores but because they have the best binned cores. If there was really demand for really high core count CPUs, we'd see it in the sales figures pushing the currently highest core SKUs up the sales charts. That's not to say there isn't some demand and every user is welcome to advocate for their own wants, but don't confuse niche wants for what the market is actually asking for.
