Page 523 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
jdubs03
1,466
1,037
So what? Apple cores operate at much lower clock speeds, are in a completely different software model (ARM) and do not offer high enough performance (if at all) to justify a mass switch of PCs to ARM processors. Most people don't know what IPC is, and for many it's about x86 and peak performance. IPC and architecture are only interesting to us (enthusiasts), for the rest of the people it doesn't really matter much.
Apple has made some inroads into Intels market share lead for laptops over the recent years. And the M4 Pro/Max should be a pretty solid package overall. The Max won’t be at 9950X/285K in MT for desktop-level performance (courtesy of its lower thread count), but it will sip power in comparison and smash the competition in ST at the same time. The Max in a laptop form factor might even match or come close to HX class performance (again at much less power).
Reactions: Tlh97
AMDK11
494
435
Apple has made some inroads into Intels market share lead for laptops over the recent years. And the M4 Pro/Max should be a pretty solid package overall. The Max won’t be at 9950X/285K (and MT in desktop-level performance (courtesy of its lower thread count), but it will sip power in comparison and smash the competition in ST at the same time. The Max in a laptop form factor might even match or come close to HX class performance (again at much less power).
How much faster will it be in ST? I don't think this is a big enough vulnerability to justify moving from an entire x86-64 environment.
For me, ARM is just a curiosity that is nice to have and shows what can still be achieved in terms of computing core design and IPC achieved. But I'm not going to give up on x86 just for this reason, and x86 is growing and will continue to be in good shape despite temporary weaknesses/downtime.
Further development of x86S 1.2 and the introduction of APX instead of 16x GPR 64-bit, 32x GPR 64-bit will provide significant benefits.
"Intel® APX doubles the number of general-purpose registers (GPRs) from 16 to 32. This allows the compiler to keep more values in registers; as a result, APX-compiled code contains 10% fewer loads and more than 20% fewer stores than the same code compiled for an Intel® 64 baseline.2 Register accesses are not only faster, but they also consume significantly less dynamic power than complex load and store operations."
jdubs03
1,466
1,037
The M4 series should be about 10 to 15% faster in outright single thread performance; based on the M4 clocking to 4.4GHz.
On a sidenote, I’m surprised that Apple doesn’t increase the clock speeds a little bit on the Pro and Max SKUs, seems like a way for further differentiation.
cannedlake240
247
138
RWC is a horrible nightmare
Then all of Intel's modern cores are? Redwood is literally just a node shrink of Golden cove. The reason it regressed a bit was due to abysmal uncore perf( ring clock <4ghz, high memory latency). Plus all x86 cores perform worse in mobile variants due to power reasons. Just look at Zen mobile vs Desktop, same with Zen 5. Lion cove is more complicated because it inherits the SoC from MTL
AMDK11
494
435
Well, I don't know if the difference is big enough to be worth switching from x86 to ARM. As I wrote, there is no gap, and changing from x86 to ARM means a gap and giving up the entire environment that I, among others, care about.
Reactions: Tlh97 and jdubs03
AMDK11
494
435
RedwoodCove in GraniteRapids is something more because it includes an 8-Way decoder like LionCove and gives a gain of about +10% to IPC.
cebri1
373
405
I believe a little bit less than that. Close to 6-7%, I think the new memory and the added cache are doing the heavy lifting. RWC+ is still GC++++. A notch behind Zen5 but not a whole generation behind. Not bad for a 3 year old arch with some tweaking.
AMDK11
494
435
Intel officially acknowledges that GraniteRapids' RedwoodCove has an 8-wide decoder, which MeteorLake does not.
poke01
4,788
6,111
almost no one is switching because Apple is 15% faster in ST and has better perf/w, these benefit Apple and Mac users only.
Now unless Apple decides to sell its chips to others only then do they pose a real threat to Intel. For now Apple beating Intel is wrong in optics only.
OneEng2
976
1,186
Depends on metrics
density it is slightly behind but on PPW it is between N3E and N5 and the fin configuration as well you can check both of these it is between N4P and N3E also the 3-3 fin is similar between Intel 3 and N3E according to wikichip
All the sources are listed stop saying Intel 3 is at N5 level outside of density unless specifying the use case which in Terms of Intel and AMD is HPC
By TSMC own admission N3P is on Par with 18A
Yes all those years of 14nm++++ and 10nm+++
Are finally ending pat should get credit for correcting predecessors mistake
I have said it many time Intel's P core team is horrendously bad look at how efficient and cool and less power Sierra forest consumes it's not because of node but because P cores are disappointing
I think it will be 25-30% dependent on workloads
It's not crestmont but a buffed up chadmont so i don't think performance per core gap will be that much wider between 5C/ and Darkmont TSMC saying 18A matches N3P so how is it struggling considering N3P is the best Process in N3 family 🤣
Intel will have 2 differentiation Supply and good SW i don't believe AMDs supply even in server space otherwise with the massive lead they have they should have taken market share crazily which they didn't it will be even tougher now
If Intel makes the 18A process release on time they will be up against AMD on N3P ... true, but I am GUESSING that Intel will release Q4 2025 at the earliest. Samsung had a he** of a time with GAA. Yields I believe. I just find it hard to believe (and have since Intel came up with the crazy aggressive process roadmap slide) that Intel is going to pull off such a large number of changes into 18A. I guess I just lost faith after the afore mentioned 14++++++ and 10+++++ fiasco :).
You may be right about the P core architecture. It seems like the perf/watt of the E cores is impressive in comparison. We will have to re-visit the performance guessing after release and see which one of us was closer :).
TSMC N4P:
3-3 Fin -> 98 MTr/mm²
2-2 Fin -> 144 MTr/mm²
TSMC N3B:
3-3 Fin -> 124 MTr/mm²
2-2 Fin -> probably exceeds 180 MTr/mm²
Intel 3:
This ignores performance entirely, that's much harder to quantify.
So Intel 3 is roughly equivalent to N4P and below N3B. This is not different from what I have read other places.
So 2024 Turin will be on N4P and therefore be about process equivalent to Granite Rapids Intel 3. Since both designs utilize "P" core only technology, it will be interesting to see how power effective each design will be when placed in the context of being design power limited.
AMDK11
494
435
This is not enough for such a radical change from x86 to ARM. If only it were 40-50% more but it isn't. I don't think over 90% of people would choose ARM (Apple Mx) just because it has a much higher IPC and an overall ST performance of +10-15%. Most people have no idea about core micro architecture and IPC. So true.
OneEng2
976
1,186
Of course, Turin D 192 core will be on N3E and provide both power and density improvements. But then, it won't be Intel P cores that this Turin will be up against (I don't believe).
FlameTail
4,384
2,762
TSMC N4P:
TSMC N3B:
Intel 3:
Where are these density values from?
AMDK11
494
435
It's probably a typo or they're talking about uop cache
Reactions: cebri1
DavidC1
2,124
3,255
Keep in mind when comparing Lion Cove to Zen 5 that Lion Cove is a mere expansion of what it was before and Zen 5 is a departure. Zen 5 is not only substantially smaller than Lion Cove, it has way more headroom for it in the future because it's a change in architecture. This is despite the Lion Cove being on N3B.
Without Skymont adding heaps, Arrowlake would have been a dud with all Lion Cove cores.
It might be "Lion" Cove, but it's more like a fat house cat.
Reactions: Kryohi
Josh128
1,510
2,262
Why not? That Zen 5C Turin is about to be announced in a couple of weeks, no?
Reactions: Tlh97
AMDK11
494
435
LionCove is a departure from Intel's approach and philosophy from P6 to RedwoodCove. LionCove is a fundamental departure from previous generations of Cove and is now more Zen than ever.
From P6(Pentium PRO) to RedwoodCove, the schedule and execution ports were common to FP and ALU, i.e. FP-ALU. LionCove separates FP from ALU and implements separate/dedicated blocks with execution ports for FP and separate ones for ALU. If no one sees such a fundamental change, I don't know if anyone will ever notice any changes.
DavidC1
2,124
3,255
Lion Cove brings absolutely no new ideas, regresses from the predecessor of 3 years ago in some aspects, and is still way bigger than competition, despite having significant process advantage.
Putting a lipstick on a female pig doesn't make it an attractive woman.
jdubs03
1,466
1,037
Unless you’re Kermit it does!
