Page 181 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
SiliconFly
1,924
1,284
Intel seems dedicated to the hybrid approach. If anything P core count will go down I think.
Looks like it. Future P cores might be more massive than the existing P cores, but might be very power efficient and might have very high IPC at lower clocks when compared to existing P cores.
TESKATLIPOKA
2,696
3,260
I think Intel will want to keep at least 6-8 P-cores.
E-cores can increase nT performance, but you also need to keep in mind how many threads the App can load.
If you have an App which can use up to 12 threads, then 8P+4e would perform better than 4P+16E.
Abwx
12,033
4,995
Yeah, what if this "pcode" update (if it's even real) all it does is boost PL2 time or power? I don't even know if the reviews we've seen that test power disable PL2 or not? because it's pointless to compare at 28W or at 45W if PL2 is much higher and affects scores significantly. I've a 12500H and I know these 13500H scores of 14200 at "65W" are absolute BS, it barely gets above 12000 points when 65W enforced properly.
So that chinese youtube review is not enforcing power limits properly, I've seen Alder Lake and Raptor Lake have similar efficiency as demonstrated by Jarrod Tech when comparing 12700H vs 13700H, so 13500H is just not getting like 15%-18% higher points at same power than my 12500H.
When set to 45W the chip boost to 64W for 35s, if set at 35W it will still boost to 64W but for a shorter 25s time, that s what was measured at Computerbase, they may play with even higher PL2 power or longer duration, that s surely their new pcode...
Actually in Cinebench and other MT benchs they even put to contribution the two LPE cores to grab some perf drops, given that they use a new process a 7840U/HS should be no match for a 6P + 10E that is the equivalent of a 11 P cores or so, if even AMD release a cut down Strix Point with 10C it will be a slaughter, we dont even talk of the 12C, even a Zen 4 based such chips would be overhelmingly dominant.
Abwx
12,033
4,995
It would seem that some people are still clueless about how PL1/2 and Tau works on Intel mobile CPUs since Tiger Lake. As a result, they clutter these Intel threads with useless information and analyses.
You know better than Computerbase, they have curves of power vs time, not bla bla from the usual nay sayer, talk of being useless, you re filling the thread disgruntedly because your favourite brand released a half baked chip...
tamz_msc
3,865
3,730
It doesn't matter who tested what. Unless Dynamic Tuning is disabled, speaking about power limits and boost durations are meaningless.
Abwx
12,033
4,995
What is useless is to talk out of the vaccum, as said Computerbase tested at stock settings, there is a 35 and a 45W setting in the Acer laptop they got, and they measured what i posted, i m talking of actual data while you re just trolling with non sense.
SiliconFly
1,924
1,284
To calculate real power efficiency, we not only need to plot the power usage curve, we also need to calculate the area under the curve and then compare ratios. No one in their right mind will waste so much of their time doing that considering the CPU power usage plots pretty much keeps fluctuating making area under the curve a nightmare to calculate. Not worth our time.
Other indirect but easier way of calculating power usage of 2 CPUs is to first ensure they have the SAME performance or at least very similar. Then running power usage tests on both CPUs designed to highlight their design goals or real world usage scenarios. Not CB.
Throwing PL1 and PL2 numbers and saying one is more power efficient than the other is just plain wrong.
SiliconFly
1,924
1,284
...Unless Dynamic Tuning is disabled...
I don't think it's nonsense. I think he may be right.
FlameTail
4,384
2,762
That's support for a whopping 16 USB ports.
Why though? I haven't seen any laptops with even 10 USB ports, let alone 16. So why is there so many USB controllers?
Abwx
12,033
4,995
Not worth your time because you are not a professional reviewer like Computerbase crew, it s their work to measure and compute the results, and they measured the influence of the turbo.
No need to throw PL1/PL2 since they did actual measurement of the CPU power over a 300s time in single and multicore with curves displayed, what else do we need..?.
tamz_msc
3,865
3,730
How do you know whether HWinfo is running on the LP E-cores or not? Monitoring software will take away certain CPU cycles, no matter if its on AMD or Intel - it was in fact a huge problem early on with Zen 2 and the boost fiasco.
And package power is simply misleading. There are four tiles on the package, each fabbed on different nodes. Why is package power the proxy for CPU compute tile power consumption?
SiliconFly
1,924
1,284
Just went thru your link in spite of better judgement. The results are pure bs. The article itself clearly states "larger differences are created with multi-core load" while comparing two MTL laptops! :tearsofjoy:
Test like these are a joke. And like I said a thousand times, MTL does not fare well in power usage stress tests. We will always get wrong results literally. It does not reflect MTL real world usage scenarios and is not designed for that.
Thibsie
1,180
1,399
Why? What's with this mentality of "Hey, we are good and even great in some cases but we don't want total market domination. People can buy Intel if they are desperate"?
Because if you play your cards right away, the other guy can play dirty tricks and nasty surprises.
Seems sales 101 to me really.
SiliconFly
1,924
1,284
Kindly ignore that computer base article. They are clueless on about how to test MTL power efficiency. They're using CB to plot MTL power usage. :tearsofjoy:
Well, they're using fancy colored graphs to impress unsuspecting readers. It's a trap.
TESKATLIPOKA
2,696
3,260
Then please write to CB and tell them how amateurish they are, but because you are so kind, you will explain to them how MTL should be tested and in what test. :p
SiliconFly
1,924
1,284
Lots of devices inside the laptop tend to use USB links. Like Bluetooth, Trackpad, Fingerprint, Camera and probable many more like ME, OEM specific features like programmable custom RGB backlit keyboards and probably more.
Abwx
12,033
4,995
If you think that they rely solely on HV Info then you never saw some pics of their lab.
They have an automated benching with everything measured including of course power at the main and between AC adaptator and laptop on the 18V supply, they know if HV infos are accurate or no, they have the gear to check the thing, just the Rodhe and Schwarz as well as Agilent analyzers they once displayed would buy you an apartment and a car as a bonus...
cebri1
373
405
That's probably the number for all type of ports supported. They usually divided them by type:
Meaning that probably if you have 5 USB 3.2 2x2 you are already saturating the BW available.
Meteor Late
347
382
One can disable PL2 and enforce only PL1, I had a 5600H and you could do a similar thing with UXTU, of course AMD uses a different name for this but still, there is no excuse for these reviewers if they want to compare efficiency properly.
SiliconFly
1,924
1,284
Looks like I don't have a choice.
I'm going to Germany, learn German, goto Computerbase in Berlin, meet MD Frank Hüber and tell him he's wrong!
That should go well I think. 🧐
Tbh, I think they should consider testing MTL's LP E cores as well.
trivik12
354
324
Thank god. We need 8GB memory to die in 2023. Memory is not that expensive. BTW are there any laptops with LPDDR5x7466. That is the fastest supported memory right?
On Early issues even Apple iphone has had early issues which was fixed with further software updates. I think Intel was fixated on getting it out before end of the year. Probably needed more QA time for packaging team. its something unprecedented(there was Lakefield but even that was not this complex). I hope Ian Cutress or Anandtech does a deep dive with different laptops sometime in the future.
