Page 93 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
i lost track of what post of yours i wanted to quote but i'd point mtl being like tigerlake on the scale but better.
Tigerlake-U was quite good. The biggest downside was the subpar multithread performance with max 4 cores. There are tons of devices still in the market.
Raichu being a Weibo resident and often just reposts stuff to Twitter has been known for ages now, this isn't some new revelation. I know for sure that I've said as much here before as well.
He does occasionally post slides and stuff that are legit, but there are also times where there are huge misses. What he's said about MTL is one of those cases.
Then please prove it. I would like to have links to his Lion Cove claims about the wide and increased ROB size. Maybe there is more in weibo which he didn't post. I'm also interested in the Redwood Cove voltage/frequency examination from here. Raichu is one of the most accurate on twitter, in fact he was one of the highest in the old Hardware Leak Tracker.
Is this happening because he was one of the highest in Hardware Leak Tracker? (no offense btw)
You've already seen MTL-P/H (they're the same thing now) ES2 publicly. Admittedly the screenshot I know that came out of that didn't show clock speeds that were useful (was a task manager screenshot showing <1GHz only), but I can tell you now they're a good bit away from 5GHz on ES2.
QS may well hit 5GHz, but ES2 did not. Afaik QS isn't out yet though so I wouldn't hedge my bets either way.
I wasn't talking about MTL-H. Is that all you have? That's why you are saying he is getting his infos over the last few years from weibu, just because of the MTL-H ES2 clock speeds? That's a new low I would say. You need more than this, much more. To me it looks like you accusations are completely wrong, it's just that you don't like him and try to discredit him. That's my feeling I got.
I don't have any personal issues with Raichu at all, I don't know where you got that from. Aside from him gunking up my Twitter feed lol. I honestly don't really care about Raichu at all, the only reason I know about him being on Weibo is because a guy I know is on there and says that about Raichu. That guy also happens to work at an OEM himself, so when he calls someone out I know for sure it's real. He makes a big deal out of it every time, which is why I know for sure this isn't the first time it's happened. I just don't really care to keep track of one of the many guys posting stuff to Twitter.
I'm not really sure what's up with you honestly, you're treating what I said as a personal attack, when in reality all I'm saying is the nature of how he gets his information means it's not 100% accurate, and that there were and almost certainly will be in the future instances where he is wrong. I think those instances should be called out I will do so. This is one of those cases, because I've heard from two entirely different people the exact same thing: that MTL-H ES2 doesn't touch 5GHz. Both of which I'd trust over Raichu any day of the week because I know they have direct lines of information.
Look no offense Mikk, but rather than try to declare new lows perhaps you should recognise the real reason you don't like me saying something "negative" about Raichu (it's not actually negative in just explaining a way in which someone gets their info when it's still a private circle where one of the sources of said information is well protected from the general public, and that there very often is good information that comes out it, but just every now and then you get duds, and that 5GHz ES2 MTL-H is one of those duds.)
I think this whole discussion would be much easier if there was any actual link given to this content on Weibo before Raichu posts it. Without that evidence, is it unreasonable for someone to attribute him as the primary source? At best, it becomes a he-said-she-said.
Seems like QS sample can only hit up to 4.8GHz for P core and 2.2GHz for tGPU, hopefully Ultra 9 would turbo up to 5GHz.... 🙄
No idea about the GPU, but they'll at least hit 5GHz. Reasonably confident of that. I think a top SKU in the 5.1-5.3 range is pretty likely.
I guess the rumors about the IPC being only a low single improvement were wrong unless MTL has lower ST than RPL but I don't see that happening.
About that...
Ah yes, let me post a screenshot/link to a closed off private group that I already said I don't have access to personally. If you're so desperate to believe something multiple people have claimed is wrong (even publicly) then be my guest.
Back to reality now, yeah this is right currently.
I'm not mikk, btw. But as I said, this is just a he-said-she-said. Why get angry at someone for asking for evidence for a particularly forceful claim being made? And you are kind of coming across as annoyed that people are taking Raichu seriously to begin with, despite an objectively good tract record. And regarding the MTL ES thing, there may not be a 5.1GHz ES2, but I don't believe that number was fabricated either, if that makes sense, so I don't see it as a real point of criticism, much less dismissal of everything he's posted.
Anyway, as I said, MTL will hit 5GHz, and likely a touch more. I don't think they're even shipping QS chips yet, so no idea what specific SKUs are out, but I'm reasonably confident of that claim for launch silicon. MTL has its problems, but the clocks on Intel 4 are tolerable enough. I do hope someone does a proper launch review of more than just the compute die though...
I'm not mikk, btw. But as I said, this is just a he-said-she-said. Why get angry at someone for asking for evidence for a particularly forceful claim being made? And you are kind of coming across as annoyed that people are taking Raichu seriously to begin with. There may not be a 5.1GHz ES2, but I don't believe that number was fabricated either, if that makes sense, so I don't see it as a real point of criticism.
Anyway, as I said, MTL will hit 5GHz, and likely a touch more. I don't think they're even shipping QS chips yet, so no idea what specific SKUs are out, but I'm reasonably confident of that claim for launch silicon. MTL has its problems, but the clocks on Intel 4 are tolerable enough. I do hope someone does a proper launch review of more than just the compute die.
I'm not annoyed at people taking Raichu seriously, I'm getting annoyed you're not listening to all of the people that have said publicly that this one specific rumour is not true. From my perspective, that rumour just wasn't true. Just because the numbers line up with expectations for what final silicon is aiming at, doesn't mean that at the time of the claim it was true.
If you think it's fine to pass on it, sure, feel free to do so, but I don't. Either it is what the ES2 does, or its an expectation of what final silicon will be able to do. You don't get to say it's one but treat it as the other. Letting little stuff like that fly is how people accept guys like MLID.
Oh and as an aside, I think at some point I said I thought GNR-AP would be decently competitive with Turin at the top end.
I'd like to recind that statement. I was very wrong. I'm sure it'll beat Genoa, but Turin is a bigger jump than I was expecting.
So where have I been saying anything about it? Frankly, I haven't been satisfied with any of the MTL ES claims/leaks and the general confusion the leakers seem to have between the different SKUs, milestones, etc., down to what's planned vs what's shipped. And I've been quite vocal about that.
I can see any number of ways for valid information to translate into misleading leaks, but for the purpose of setting expectations for final silicon, this isn't worth the crusade vs any number of far more baseless takes. And also doesn't address the Raichu vs Weibo leak question.
You see anyone who is projecting MTL silicon accurately? Because I sure haven't.
That, I'm curious about. I think the hype train has been going a little too hard for Zen 5 in general. I expect Turin to win, but not by anything huge. Still expect the two to be approximately competitive, all said and done.
The biggest issue has been that plans have been changing considerably for MTL/ARL for a while now. For the longest time nobody could guarantee what the SKU stack looked like. Things are probably locked in by this point, but we've seen entire dies get dropped in the last year or so (like the old 6+16 MTL and 8+32 ARL). We literally all just found out that neither 6+8 nor 8+16 for ARL is being fabbed in-house for the main core die, so nothing is really left in-house. So when it comes to specific SKUs the big issue is that it was all in flux for the longest time. I don't think anyone wanted to say anything about it. But I'm just guessing what other people are thinking at the end of the day.
As for what's planned vs what's shipped, that much at at the very least I think you can figure out with good filtering.
I think I've made myself clear already. I'm purposefully moving away from that stance.
To some degree, yes, but MTL-S was always on-again off-again. The MTL M/P roadmap never really changed. Little bearing on clocks either.
There should be two 6+8 dies. N3B and 20A. I still don't think that 20A one is canceled. Not going to claim it as fact, but I certainly would not trust rumors.
Yes, I was just explaining my own understanding of the matchup.
Wdym hype train; the samples for non-Dense Zen5 are everywhere.
HAHAHAHHAHAHAHA ohohohohohoohhohoho jesus.
GNR is approximately competitive with maybe Genoa if it's lucky.
Turin is just a different realm of existence.
On Sisoft there are tGPU entries with 2.25 Ghz:
It's exactly a TFLOPS doubling over Xe LP 1.5 Ghz (4.6 vs 2.3 tflops). By the way earlier this year Raichu told the original target was 2250-2300 Mhz. Seems like they can hit this target.
If you have numbers for both, than post them. Otherwise, this is unhelpful at best. As for GNR, are you seriously claiming that ~128c wouldn't even beat Genoa?
My info didn’t come from Raichu, and to be clear, I never said ES2 hit 5+ ghz. I said the highest speed reached by these chips was around 5.4ghz. That was for an early unfused sample. What I DID say was the final clocks would be 4.8-4.9 ghz, and well what do you know, the QS appears to be clocking in at 4.8 ghz.
Unless things have changed, there will be no Core 9 Ultra this gen. The i7 sample will clock around 4.8-4.9ghz and minor IPC/architectural improvements will carry the chip the rest of the way.
Fastest 45W i7 13900HK has 5.4GHz turbo, If Meteor Lake will clock only at 4.9-5GHz then It needs 8-10% IPC gain just to be on par with It, anything less and you have regression in ST performance.
I think they will try to at least keep ST performance the same.
I kinda don't care about It unless It affects games. What I am more interested in is the MT, IGP and power consumption.
There will be Ultra 9 variants.
