Page 805 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Thunder 57
4,206
6,993
We also don't get detailed articles like old AT no crap just plain info
I miss the deep dives. I wonder they largely stopped because people don't care, or if companies give out less details about architecture these days? I'm inclined to think the latter. Still C&C manages to get into detail though.
511
5,118
4,605
Same Deep Dives are the best but in modern era clickbait/misinformation sells but not Correct Info.
Doug S
3,746
6,613
It may have had more to do with the cost of keeping the people talented enough to properly do those deep dives. When you have guys getting hired away by big tech firms or starting their own sites there wasn't going to be anything they could do to keep them. If they don't have anyone capable of matching that and/or they aren't willing or able to pay enough to hire one you those deep dives go away. Now you have someone like Geekerwan who could do those but he why should he work for someone else when he can site up his own site/channel and keep everything for himself? And not have any boss telling him what to review or worrying that him criticizing the wrong company will hurt the site's advertising revenue!
Apple has never given out much info about their architecture, but today Apple's architectures are MORE open today simply because having it on Mac makes it a lot more accessible than when it was only available on a locked down smartphone platform.
Fjodor2001
4,423
663
That's not surprising. That scenario is great for E-cores and that is no secret. From just above in the article:
It would seem that is very much an "it depends" scenario. Intel has made great progress here, just look at the 14900k scaling in that graph.
Well, it seems to be a surprise to some that were concerned about NVL-S not having 300+ W TDP. :)
Then regarding the test I linked to, I agree that the E cores shine in that scenario. But since it's an MT test, the P cores will be running as well in parallel, which means they're of course also included in the measurement. So they must also have much better perf/watt when not being pushed to max frequency.
Finally, for NVL-S 52C there will be 16P + 32E + 4LPE cores. So if E cores is what makes Arrow Lake-S perform well in MT scenarios when not pushed to max frequency, I think we can expect NVL-S to also perform well in such scenarios since it'll have a lot of E cores.
AcrosTinus
221
226
If the leaks are true, the SKU design for the Ultra 7 suggests that the two compute die theory might not be true. I really think that we will see basically this in a ring:
4xE--2xP--4xE--2xP--2xP--4xE--2P--4xE
16stops, elongated die, an imaginary evolution of the current one.
dullard
26,185
4,841
I don't follow your logic. Could you explain more?
What if Intel had these chips:
A: (8P + 16E) sold as the top Core Ultra 5.
B: (6P + 8E) with some cores disabled due to a defect, sold as the bottom Core Ultra 5.
C: (4P + 8E) with even more cores disabled due to defects, sold as the top Core Ultra 3.
D: (4P + 4E) with even more cores disabled due to defects, sold as the bottom Core Ultra 3.
Then why wouldn't the Core Ultra 9 be two of the A chips, (8P + 16E) + (8P + 16E) = 16P + 32E?
And then why wouldn't the Core Ultra 7 be one of the A chips and one of the B chips, (8P + 16E) + (6P + 8E) = 14P + 24E?
There would be no reason to combine the lower performing chips into a top tier CPU.
eek2121
3,458
5,105
While I won't bet on current rumors being right, everything I've seen indicates that Intel is planning (or did plan) a dual chiplet part.
They may not even be using a ring bus at all, or they could be using a ring of rings, mesh, or some other topography.
At any rate, a dual chiplet design would most certainly be an Ultra 9 part, not an ultra 7 part, if is part of the Core series at all (it could be Xeon or something).
Fjodor2001
4,423
663
Regarding LPE core on NVL, what are we expecting to be used for that? Will it e.g. be a downclocked E core, or completely different arch compared to P and E cores?
AcrosTinus
221
226
I am just guessing, they would just have a completely different die for the lower products, the same for the current generation. In the current one, the Ultra 9 and 7 have the same die, the others don't. On some SKUs the heatspreader is even different.
I am most likely wrong but that is what I image, because how would the base die look like ? Would there just be a dummy die or a blank like on single CCD Ryzens?
AcrosTinus
221
226
You might be right, a mainstream mesh by intel might be the simplest explanation.
LightningZ71
2,644
3,324
I still wonder, especially now that the designs are node agnostic, why can't the smaller, lower performance core dies be on an older, less expensive node? For instance, their 4P +8e die could be implemented on a dense library Intel3 chip that would fit the space of the 8p+16e chip.
jpiniero
17,006
7,406
The only Intel node with any real volume is 10 nm and friends.
Reactions: Joe NYC
DavidC1
2,021
3,157
Downclocked E core. They don't have a third uarch. Not only you need additional monetary and personnel for such new development, they need additional research to reach a point where they find a good balance with it. The first Atom uarch sucked. The Out of Order Atom improved so much that it offered all the benefits of the new uarch without negatives such as increased power and area.
Meteorlake's dual Crestmont was too slow for even browsing/Youtube duties. So making a slower core than the E core makes no sense.
I assume that's because the cores still benefit from new nodes in both power and area while IO transistors such as in the SoC tile stopped scaling a while ago. That means for cores it's not really beneficial in terms of cost to spend extra time and money porting to an older process.
DavidC1
2,021
3,157
Right, N3B is much more denser, But that's the case with the most dense configuration...
I still don't know what kind of N3B configuration of Intel is using in Arrow Lake...
What are you talking about? N3B is straight up better than Intel 4. There's no competition.
Lion Cove/P cores just suck, that's it. You can compare to AMD. Zen 5 is on a worse node and the core area is significantly smaller. And Zen 4 was way better than Golden Cove that's used in both Alderlake and Refreshlake(also re-Refreshlake)
Their P core vs E cores are just like Pentium 4 vs Banias. I'm pretty sure some made the argument that Pentium 4 clocks much higher. Yes, but at some point you have to ask.
Gracemont vs Golden Cove made sense. Skymont vs Lion Cove absolutely does not. We went from being 40% perf/clock gap in Int + 70% difference in FP + 40% clock difference + SMT to 10% perf/clock in Int and FP + 24% clock difference without SMT. The decrease in ratio from ~4:1 to ~3:1 can be explained entirely by huge increase in FP performance.
There's a legitimate reason for their hybrid strategy. They literally cannot put same amount of P cores as AMD without consuming power like a RTX 5090 video card.
Io Magnesso
578
165
Their P core vs E cores are just like Pentium 4 vs Banias. I'm pretty sure some made the argument that Is it an HP cell?Pentium 4 clocks much higher. Yes, but at some point you have to ask.
I'm sorry it's hard to understand
What I'm talking about is how Intel used the N3B cell library? I just wondered
Is it an HP cell I wanted to say that Sorry for my lack of English
DavidC1
2,021
3,157
At 5.7GHz clocks it has to be the best cell. Arrowlake would have been a lot worse if it wasn't for Skymont.
Reactions: Io Magnesso
511
5,118
4,605
ARL problem is that it sucks in games, and Skymont does nothing there.
If only we got 5Ghz Skymonts like the guy running in games
Most likely 3-2 FinFlex
