Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 792 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
750
703
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4TSMC N3BTSMC N3BIntel 18A
DateQ4 2023Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P8P + 16E4P + 4E4P + 8E
LLC24 MB36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
2,270
1,940
Assuming they have already solved some or all of the tile related problems in Panther Lake, it seems logical that they can do something better with the ARL Refresh tiles, unless they decide it's too much work with not enough time.
Panther Lake is near monolithic only iGPU being the separate one.
17,247
RAM is not on package so it will face the same latency issues as ARL unless they have solved that somehow.
If the above is to be believed, they lose this power advantage with Panther Lake and need to make up for it somehow. Either larger cache to reduce memory traffic or depend entirely on 18A's power efficiency.
511
2,270
1,940
IMC is on board the CPU die in Panther Lake also this is LNL specific optimization i doubt any non MoP solution will come close to this one.
Fjodor2001
4,049
463
Improving the NPU is still an exercise in futility at this point, it does not help short term and is likely to be too little for the future. Same applies to AMD.
Needed for the 40+ TOPS to get the Microsoft AI PC sticker. PC manufacturers will want that on their boxes when the Windows 12 upgrade cycle starts.
Reactions: 511
dullard
25,820
4,378
From Chips and Cheese, they feel Intel has two separate latency issues which hold the performance back. (1) All the stops on the ring bus which include stops for cross die transfer. And (2) Intel's cache coherency protocols. With respect to Lunar Lake, there are only a few ring stops and the memory is on board and yet there is still high latency. That is their evidence that they think issue #2 is playing a significant role.
Cache coherency protocols ensure only one core can have a particular address cached in modified state. Thus the requesting core in this test will miss in all of its private cache levels. When the core with modified data gets a probe, it has to check all of its own private cache levels, both to read out the modified data and ensure the address is invalidated from its own caches. Lion Cove goes from two levels of core-private data caches to three, adding another step in the process.
A look back at Lunar Lake supports this theory. Lion Cove also sees high core-to-core latency there, even though Lunar Lake’s ring bus only serves four cores. Lunar Lake also displays high cross-cluster latencies, even though those transfers don’t cross die boundaries. How a memory subsystem handles cache coherency operations at the logical level can make a bigger difference than physical die boundaries. and Lunar Lake may be a good example.
In other words, having the RAM on package helps, but does not solve Intel's high latency.
2,270
1,940
From Chips and Cheese, they feel Intel has two separate latency issues which hold the performance back. (1) All the stops on the ring bus which include stops stops for cross die transfer. And (2) Intel's cache coherency protocols. With respect to Lunar Lake, there are only a few ring stops and the memory is on board and yet there is still high latency. That is their evidence that they think issue #2 is playing a significant role.
Don't forget AMD Strix Point latency is in similar boat to Lunar Lake. These designs are optimized for power instead of performance.
I was never a fan of adding cache hieracrhy these adds more problem than they solve them i hope they fix it in Panther Cove.
Fjodor2001
4,049
463
i said /jk at the end. :sweatsmile:
On a Sidenote Looks like my jokes/sarcasm are difficult to understand. 🥲
You should have posted this instead ;)
DavidC1
1,465
2,402
Let me ask you this then. How was Raptorlake so fast in terms of latency? Think before you post man.
On package memory is absolutely insignificant in terms of latency. If it was the sole factor then the smartphone/tablet parts with memory right UNDERNEATH the chip would be absolutely the fastest, yet they are slow as snails.
Saying whether it's on package or not matters for latency means it's mostly limited by speed of electrons(which is similar to light), but RAM is hundreds of times too slow for that to matter.
Lunarlake's on package memory play is entirely about power, nothing else.
The real issue is that Intel is a shadow of what it used to be. C&C article is saying in a very roundabout manner that Intel has crappy engineering due to decades of mismanagement.
Before the brain drain, they could take a garbage design and make it ok.
2,270
1,940
The real issue is that Intel is a shadow of what it used to be, and the endless brain drain over past few decades is the reason for low performance on Intel.
Totally many have retired or switched Jobs. Apple's design team is almost Ex-Intel. I have also seen somewhere Nvidia Litho team is ex Intel as well.
Reactions: lightisgood
DavidC1
1,465
2,402
Sometimes I get annoyed at Chips & Cheese articles. They KNOW perfectly why Arrowlake sucks.
Writing 10,000 word articles to try to "technically explain" it away doesn't change that.
It's like trying to explain why someone has shot themselves on their foot.
Thunder 57
3,667
6,184
I like their content usually. But I don't like them because they posed an open question; Should we move to Substack? The responses were a resounding no. They did it anyway. Why ask if you are going to do it regardless?
DavidC1
1,465
2,402
I like them too, but they have a lot of spurious articles. They are the best at what they are doing, which is the sad part. Because during the peak of Anandtech, the articles out on the internet were simply superb. Xbitlabs, Anandtech, Beyond3D, Realworldtech, they were miles better.
Guess it's way better than video articles which reduce content by 10x while increasing time to search for relevant data by 10x too. Pictures might be worth a thousand words, but thousand videos might not be worth one article.
They feel second rate. Also older articles didn't shy away from critiquing what they were reviewing. C&C doesn't know how or are scared to do it.
Thunder 57
3,667
6,184
Anandtech used to be the gold standard. Xbitlabs was nice they are back again but a joke. Never really used Beyond3D. RWT was great too.
DavidC1
1,465
2,402
I'm talking about the old Xbitlabs of course. There's another site I can't remember which had absolute gems of articles. Technically they were superior to Anandtech, and I learned a lot of fundamentals there. Anandtech had more articles and had more relevant bits most of the time plus they were closer to industry.
The writers then put in a lot more work compared to what they got out of it. The writers nowadays put a fraction of work for lot more reward. Now it's all about chasing that juicy viewer count or $. Back then it felt as if the writers owed their fans a service. I wasn't a fan of Ian Cuttress either. I could immediately feel the quality went down.
Thunder 57
3,667
6,184
I thought Ian was great at least when it came to CPU's. If anything I think Ryan was responsible for the downfall of Anandtech. He must've pissed someone off to stop getting GPU's to review. Then he went and blamed it on wildfires. And he turned down Ian's idea to have a youtube video portion for Anandtech in addition to the written articles.
