Page 654 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
AcrosTinus
221
226
Maybe they can release a 280K SKU with 6P+16E to dial down the power consumption a bit or higher all core clocks for both P and E cores (maybe 290K in that case?).
Cope on :
There is a reason Intel left so much space in the naming, remember the ADM LV4 cache, my "Sooooooooources" told me it was for the gaming version of Arrow Lake. Let AMD run into a trap of taking the crown in gaming just for it to be snatched away in a humiliating defeat.
Meteor Late
347
382
It is getting hard for me to take Intel process timelines seriously because they seem to miss their deadlines so regularly. ARL disappoints architecturally and isn't on Intel 20A. Might be time for an AMD/Intel pair trade.
It just seems like IPC-wise x86 is nearly topped out. Zen 5 didn't show big gains and Lion Cove showed gains and regression. It seems more likely that the E cores will approach current ST iso frequency performance and peter out as well at that performance level as well, they just end up at that performance level in a more area efficient manner.
Without software help like new instructions or something I don't see how we get another 15 to 20% increase on a generation from either Zen 5 or LNC? 8 wide is already too wide, right?
On that same note, considering performance regression is LNC still +9% over Raptor Cove?
Apple did get the biggest IPC boost since M1 with M4, and I think it was around 8% or something like that. I understand it's not all about IPC and frequency is the other part of the equation, but it seems IPC gains have been shrinking in both camps, at least the ones with highest performance to begin with.
Don't think IPC is nearly topped out but it seems like it's just harder and harder to obtain.
Meteor Late
347
382
Non-English YT video showing the 245K as more efficient and faster than 9600X:
But slower in games obviously.
No idea how accurate or true the bit about lower power consumption is, though.
Maybe Intel has a chance now to convince budget users to go for Arrow Lake?
EDIT: Scratch that! From same video:
Left ARL and right Zen 5 in PUBG. ARL is legendarily bad!
Guy trying his best to teach his followers that Zen 5 delivers more frames using more power :D
More cores increases the MT efficiency vs less cores due to the quadratic relationship between voltage and power, that is to say, increasing frequency 33% is going to increase power way more than increasing number of cores by 33%, or conversely, a 8 core CPU will be much more efficient than a 6 core CPU by just reducing the frequency a little bit.
So 245K has 6 + 8 cores without HT and 9600 has 6 cores with SMT. The core count difference is really big, if you add the +20-30% of SMT, it's like 14 vs 7.5 cores, almost double, MT efficiency is going to be better with 245K. On the other hand, 285K is 8 + 16 cores vs 9950X with 16 cores with SMT, it's closer in core count if you add the +20-30% of SMT, it's like 24 vs 20 cores, like 20% more. E cores would make the count a bit less but you get the point.
Hulk
3,857
Here's what I don't comprehend when people around here (who know a lot more than I do about this) say IPC isn't nearly topped out.
IPC relates to single thread performance. Correct me when needed with my somewhat naive line of reasoning.
Single thread is essentially a sequential line of instructions that must be executed one after the other (theoretically) and the problem when trying to execute them in parallel is that some instructions in the front of the line require the result from the back of the line. The result is that you can simply take 10 instructions and execute them at the same time because of interdependencies among the instructions. I have done some coding and have a basic understanding of how this works.
This is why we have out-of-order caches, branch prediction, and other "smart" structures in the microprocessor architecture that do their best to extract as much parallelism as possible from the code. It amazes me that people have actually devised methods to execute instructions out-of-order and make it work actually.
So to my question. Eventually there seems as though there must be a limit to how much of a given sequential code of interdependent instructions and can be executed in parallel? I assume some points of the code are very ameniable to parallel execution and then other parts get very dependent on neighboring instructions and the result is branch mispredictions, pipeline stalls, and other slowdowns.
So when it is said, "we have a long way to go with increasing IPC" it seems like the very nature of the instructions and their interdependencies contradict that statement.
Okay, that's what bouncing around in my brain regarding this. Please feel free to expand my horizons on this topic and let me know where my understanding is incorrect.
ondma
3,316
1,708
non-K is the volume desktop. 4P+16E as a volume SKU only works if the bins allow it to.
Why would you need 16E for mainstream desktop? Seems like even 4P alone would be enough; for sure 4P/8E should do it.
As far as that goes, I would think even 8E would suffice, with the big jump in E core IPC.
adroc_thurston
7,886
10,601
6+8 is the INTC MSDT offering now.
Doug S
3,746
6,613
N2P won't come until later half of 26 and only for apple it is 18A for majority and Graphics+IO will be TSMC
I doubt Apple will ever use N2P. It arrives at the same time as A16, which is N2P+BSPDN, so that's what Apple will use.
Reactions: jdubs03
DavidC1
2,021
3,157
For x86 they have the insane clock speed focus plus their execution sucks. If M4 is close to the peak of what can be achieved, then that's how much they can get better.
4000 in GB6 ST on a 4.5GHz chip, nevermind the power consumption differences. AMD/Intel are currently embarrassing.
How is it justified in any fashion to have a 5.7GHz chip consuming enormous amount of power, risking degradation, and having to clock rest of the chip wayy lower, decreasing density, when it loses to a 4.5GHz one?
poke01
4,606
5,916
Is there a 1080p game benchmark where Apple is shown to be superior in handling game engine performance than x86?
for gaming 9800X and later the 9950X3D will be leaders despite IPC advantage. IPC isn't the end all. Apple will however remain king in laptop power efficiency
OneEng2
958
1,172
Intel's "five nodes in four years" kept too much capacity out of service doing upgrades, plus they've been playing catchup on acquiring EUV scanners. I think that's the real reason they canceled 20A, outfitting for an internal only node that will be used by only one or two products just doesn't make a whole lot of sense. It also causes problems for Intel's "copy exactly" strategy if the nodes aren't around long enough to get copied to other fabs, because those other fabs are being set up for the next node in line.
I didn't read the transcript but from what I heard they claim to have added two customers for 18A. Whether they add meaningful volume I don't know.
Indeed! Intel's "Copy Exact" philosophy made them a ton of money over the last few decades. Changing equipment and nodes so quickly must have totally decimated this approach.
I think the issue is more complicated than you are making it out to be (and others). Yes, in the past we have seen some pretty crazy IPC improvements .... and ILP improvements ..... and MT improvements; however, almost all of it has been accomplished by increasing transistor budget and/or power budget.
As we see the end of quick gains of transistor budget and power budget, only small incremental changes to general computing can be accomplished .... and then only though very clever designs.
The only "big" changes in performance I believe will come from new specialized cores designed for specific tasks.
Zen5 is still much smaller vs Apple cores.
4-wide decode vs 10-wide
8-wide rename vs 10-wide
6 ALU vs 8 ALU
448 ROB vs 960
You don't happen to know how big the die area is for various apple cores?
Cope on :
I can't decide if you are being serious, or telling a very good joke.
For single threaded performance, I believe that essentially he with the bigger transistor budget wins (or should win).
For DC loads, it is more complex. It is more about PPA and staying within a power budget.
Hulk
3,857
So true. The IPC doesn't matter much if the decoders are constantly waiting on memory for data. This is why improvements in the memory subsystem without any IPC changes can improve throughput at iso frequency. This is what we saw with the move from Golden Cove to Raptor Cove when the L2 was increased and performance increased a bit.
Meteor Late
347
382
Most likely not, especially with the use of slower LPDDR with worse timings and all that, but also lack of big L3 cache. Memory and L3 cache have been the main enablers of AMD and Intel gaming performance increases lately:
-With Alder Lake and Raptor Lake, Intel increased L3 cache across the stack, so that even with DDR4 there was a gaming improvement, but also DDR5 improved things a lot.
-Zen 1 had 8MB L3 per CCX, so that's what a core could access. Zen 2 CCD doubled L3 cache, with each CCX having 16MB L3 cache. Zen 3 got rid of CCX and now each core could access the full 32MB. Zen 4 got no cache increase but DDR5. Zen 5 got no cache increase and same memory support, hence paltry gaming results compared to Zen 4.
Reactions: Tlh97 and Executor_
DavidC1
2,021
3,157
See, gaming performance is like how things were with Core 2 and the Nehalem.
Core 2 had a really good architecture but they had FSB and off-die memory controller so it wasn't that good in servers compared to Opteron. But once it got point-to-point interconnect with QPI and IMC with Nehalem it dominated, because the underlying core was good.
If Apple chips ever optimize for gaming, then it can fly, because it has a ridiculously good core. Let's say a hypothetical M7 with dedicated L2 per core, L3 cache, optimized interconnect, and X3D like memory and it'll fly.
poke01
4,606
5,916
6 ALU vs 8 ALU
448 ROB vs 960
For a 10-wide core its really efficient. AMD and Intel and ARM or even Qualcomm are no where near close to Apple in that department while offering the fastest core.
Reactions: Tlh97
poke01
4,606
5,916
It would be so hard for ARM even with Apple cores to be good at gaming. There is so much optimsation that goes into x86 in terms of software for games.
Now with the Switch 2 and IF Nvidia makes an ARM SoC for WoA that will change but until then x86 will remain the king for gaming. Apple SoC is great for productivity but at end both ecosystems will exist in their own bubble, it really it always depends the persons use case.
