Page 639 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
921
835
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Jan Olšan
604
1,186
FLAC encoding is multithreaded.
Does the MT encoder achieve the same compression ratio though? There was even a GPGPU encoder for FLAC once, but that was precisely the problem.
(Just run more instances at once...)
ondma
3,316
1,708
Here is my take on multithreaded performance. I too thought it was a terrible decision to remove HT from ARL. Now, I am not so sure. Still doesnt make sense to me, except maybe from a security point of view. However, MT performance of ARL in fine in the apps that it works well for. The fact that it does so well in some nT apps and badly in others makes me think there is some other bottleneck or flaw in the architecture. There does seem to be sufficient raw computing power there when it can be effectively utilized.
As to how important nT is to the average user, this is my point of view. I use my PC primarily for gaming, but also for some light video editing. Gaming performance is by far priority one. It doesnt really matter that much to me whether I can encode a video in 15 min or 20. I can just start the process and go do something else until it finishes. OTOH, there is nothing I can do if the cpu doesnt provide good gaming performance, other than perhaps changing settings. So I can easily work around limitations to nT performance, while I cant do that for gaming without sacrificing video quality.
Now obviously, depending on ones use case, the priority could vary. For sure if one is doing video editing professionally, it is essential to complete the job as quickly as possible, so the priority would be more to nT performance.
Reactions: Tlh97 and OneEng2
Hulk
3,862
It is hard to argue against this:
and even harder when you consider this:
ARL is competitive but Zen 5 wins the game. Also, the apps where ARL wins by a good margin are probably enhanced by the NPU, which Zen 5 does not have.
Kocicak
1,177
1,232
Here is my take on multithreaded performance. I too thought it was a terrible decision to remove HT from ARL. Now, I am not so sure. ... It doesnt really matter that much to me whether I can encode a video in 15 min or 20. ...
With 24 core Intel CPU, the HT benefit is about 10%, if the app can really take advantage of it. So you are looking at 15 vs. 17 minutes.
The story is a little bit different with AMD CPUs, when all 16 cores can do multithreading, there the benefit is higher.
ondma
3,316
1,708
Of course, the 15 vs 20 min was just an off the cuff number to make my point. Losing HT probably will hurt more on lower end of the stack CPUs though, since they have fewer E cores. Something I didnt mention though, is that whatever reason Intel used to decide to remove HT seems like an indication of the fact that the P core is a poor design, since AMD uses it on all cores and still is more efficient.
ondma
3,316
1,708
Actually, that makes ARL look better than I thought it would. If you remove the -68% outlier, ARL is nearly equal in applications, and competitive in power usage. The big problem is the horrible and inconsistent gaming performance.
desrever
323
797
Remove the AI bullshit benchmarks in there and its slower in 90% of applications. Why would you remove photoshop as an outlier when it is a legit application?
ondma
3,316
1,708
Of course, you can remove any benchmarks you want. You could look at it the other way and say ARL is more "future proof" because it utilizes AI. My point simply was that the benchmark is clearly an outlier.
Hulk
3,862
Let's talk use cases. I have two main rigs. My 14900K desktop and my old 8250u Skylake MS Surface 2, which is overmatched for much of what I do.
Here are the applications and operations that when I do them on my laptop I wish I was on the desktop. I am going to buy a new a new laptop soon but really want a Surface Laptop with Lunar Lake so that is why I haven't purchased already.
PureRaw for RAW photo conversion. I can batch this on either system but it painful low without a GPU. 15 seconds per photo with ARC750 desktop, 264 seconds per photo with Intel Graphics 620 in the Surface Laptop 2. That is more than an order of magnitude.
Magix Vegas Pro 21 for video editing/encoding. There are two parts to this timeline preview and rendering/encoding a project. I need the strong P cores and my ARC750 to make editing creatively possible and not painful. It is painful on my laptop. Encoding is also much faster on the desktop but not impossible on the laptop as I can run it overnight if needed. Encoding using Voukoder in Vegas will load up the P cores to 90%+ and the E's to around 60%. Encoding two projects simultaneously (2 Vegas instances open) will load all cores to 100%. It's rare that I need to do that.
Photoshop. I can do some photoshop work on my laptop but it is cumbersome and I'm waiting too much.
Presonus Studio One. Multitrack recording is no problem on the laptop as most of the heavy lifting is done by the interface. The P cores are needed for mixing when the plug-ins get heavy.
Topaz Photo AI - Relies heavily on both GPU and some CPU. I can process a photo or two in a pinch on the laptop but it's quite the painful process.
Topaz Video AI - Forget about it on the laptop. No way. It's quite taxing on the desktop with the ARC750 as well but doable.
Time Xpress. This is payroll software I use for work. Running a report takes a long time, like 5 or 10 minutes on the laptop. Again, doable, but there are things I could be doing with this time.
Opening CorelDraw, MS Phone Link, and a few others I can't remember right now seem to take forever on the laptop. Of course this is more a slow memory/SSD/storage system issue rather than a compute one I would think.
19,203
These may get a higher uplift with a Geforce GPU than a CPU upgrade.
Reactions: Hulk
19,203
285K setting new records in some of Igor's professional workstation benchmarks.
Just imagine how invincible it could've been in these same benchmarks with an extra 15 to 30% "free" HT performance.
I think the current CEO has some sort of curse following him around which is why he is so afraid of the Devil and keeps tweeting Bible verses. He hasn't had a single slam dunk since he joined Intel.
GTracing
478
1,114
What's your issue with Pat? Did he poison your dog or something?
Tup3x
1,287
1,418
LibFLAC is not multithreaded. Pretty much all multithreaded audio encoders are more or less experimental. In any case, it makes more sense to just convert multiple tracks parallel. You can basically treat is at as pure single threaded operation in 99% of software out there that people would use.
MS_AT
913
1,830
I doubt any of the benchmarks used by TPU are NPU enabled and NPU in ArrowLake is nothing to write home about.
You are estimating HT gain of LionCove based on RaptorCove and Lion is noticeably wider core than Raptor. It stands to reason it might have higher HT uplift than Raptor, since more of the core is likely to sit idle, but we will never know.
If it was free they would have implemented it;)
desrever
323
797
He's done a better job than his predecessors. He's no superman. But not a wimp either.
By what metric? Intel is just as bad now if not worse off than under any previous CEO. Their future is also worse than ever. Pat is the worst CEO in Intel history at this point since he is driving the company to bankruptcy. Intel stock in down >60% since he took over.
I'm not defending him? I'm just tired of reading comment after comment of armchair CEOs bashing him for every reason they can think of.
Because the CEO is responsible for the company and its in their job description? Why does anyone need to be an "armchair CEO" to give criticism?
Reactions: Tlh97
adroc_thurston
7,896
10,617
Well, no, the current crop of products wasn't made under his tenure. Pat will be judged by foundry efforts and stuff like Unified Core in the end.
They're just 2012-era AMD. They may recover.
MoistOintment
129
203
But how much of that specifically due to decisions he made? The biggest damage he did to the stock was cutting the dividends, even though that's what was needed for the company. Lip-Bu Tan resigned because Pat was laying off only 15% of the workforce - he wanted much bigger layoffs. MTL/ARL, SPR, RPL - all inherited messes that had the wheels in motion already.
Realistically, what choices would you have done differently?
I like that one of the first things he did was cancel stock buybacks. That he's forcing fab front and center with separate reporting with industry standard PDKs and tooling. With Intel design required to use industry standard designs that are foundry portable. I like the renewed focused on mobile, even if it hurts me personally due to the lack of focus on desktop.
Intel as a company has a lot of missteps due to past errors: Entering AI and dGPU too late. Adopting EUV too late. 10nm failures with no backup plan. The mess that is MTL/ARL - all inherited messes that he's trying to navigate through the consequences of.
I'm bullish on Intel's long term future and bearish on their short term. I think he's laying a lot of important ground work success that the next CEO will get credit for.
Hulk
3,862
Free? Aren't extra transistors associated with HT? Extra transistors mean additional die area, hot spots, and potentially reduced frequency, which is the point of the P cores.
Furthermore you are talking about extra performance from the 8 P cores so let's make sure we are throwing around numbers that make sense. Before doing calculations I have a feeling 15 to 30% is wildly optimistic consider the fact that Skymont carries the weight of the MT performance for ARL.
Assuming 5.4GHz could be maintained when HT is actually improving P cores performance by 35%, which I doubt without serious cooling, then 35% additional for the 8P cores would result in +14% overall performance in CB R24, which is higher than your low estimate and probably the best case for such a situation.
The reality of the situation as explained to us by the stupid Intel engineers, which all of us are smarter than, and the really stupid CEO, who any of us could replace tonight and we could turn the company around by next week, is that anything that hinders ST performance is illogical and a detriment to the ARL design philosophy. You see thermal considerations and transistor budget are a real thing for those dumb engineers. Of course we know better but they are stuck in their old ways I guess.
Hulk
3,862
Of course that is true. But the reality is that on average it takes me longer than 15 seconds to open, edit, and save a photo in PS so the PureRaw conversions are working faster in the background than I am in the foreground. There is a point where fast enough is fast enough for me.
