Page 634 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Kepler_L2
1,044
4,476
Cypress Cove: 18%
Willow Cove: 0%
Golden Cove: 19%
Redwood Cove: 0%(arguably minus)
Lion Cove: ~10%
Based on this trajectory Cougar Cove is the 0% shrink and Panther Cove is maybe 10%.
Do you know Exist is saying that 20A was so bad that it would have resulted in a worse Arrowlake?
AFAIK 20A ARL-S samples had an FMax of 5.0 GHz.
Reactions: Elfear
Philste
307
485
Gelsinger started his return to Intel beginning of February 2021. That is 3.5 years before arrow lake launch.
Might still be too late to radically change arrow lake, but certainly enough time to influence it.
Don't forget how crappy Intels execution was/is. MTL and ARL are both a year late. MTL Tape in was in 1H 21 (official Twitter Post by Intel) and tape out around Alder Lake Launch in September 2021. ARL is MTL with new Core Archs on the Compute Tile. So yeah, Pat didn't have much influence on that one.
511
5,118
4,605
Its become better not that good vs AMD/Nvidia though PTL/Clearwater seems healthy but we will see how it turns out 12Xe3 should be good and Darkmont without ARL Issue
It's surprising how uncore is messing the Cores along with slow L3
Henry swagger
513
313
Golden eagle will finish off the p core team.. lion cove is an embarrassment.. apple is giving cpu design lessons to intel 🙄
gaav87
659
1,279
Idk from the kernel driver access i have xe3_lpg has same MOCS table's as xe2_lpg. So same cache and memory guess no gddr7 for celestial. My guess they just increased core count per slice vs xe2.
Kepler_L2
1,044
4,476
Celestial dGPU would be Xe3_HPG. But rumor is that it's cancelled anyway.
Tigerick
919
834
Above picture said a thousand words:- 20A version of Arrow Lake is on track for H2'24.... Pat either don't know what the true progress of 20A is or simply promised something he knew won't be coming. I let you guys be a judge :cool:
cannedlake240
247
138
They know cancelling nodes absolutely won't help improve their fabs reputation. So it was more of a financial decision. Even if the yields weren't up to hvm standards they'd still do a paper launch as a tiny portion of the whole ARL supply.
Meteor Late
347
382
Diamond uses Panther cove which is an update over Cougar Cove which itself is update over Lion Cove
TSMC Nodes aren't easy to work with at High voltage
This is the first iteration of TSMC 3nm, N3B, the worst performing version of their 3nm. Please tell me what was the performance of Intel's first iteration of 14nm, 10nm, Intel 4?
I mean, it sounds great seeing how high Intel chips can get to clock, until you realize how many refinements their node needs to do so.
Reactions: 511
IEC
14,605
6,093
Roman heats up some Arrow Lake chips above 160C to melt some indium solder and delid chips:
Delidding tools seem to cost $arm and $leg due to 90 Euro cost of just the heating/temp sensor element alone so probably not worth it especially given the cooling doesn't seem to significantly limit OC potential.
Doing the old mechanical fatigue method apparently leads to dead chips. Thus the need to melt the indium solder to minimize the mechanical stress.
cebri1
373
405
Deliding reduces temps by 20C :O
Edit: WTF
