Page 633 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
920
835
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
H433x0n
1,224
1,606
The curves we have for Cinebench R23 show it is efficient only at the TDPs they didn't ship it at.
Okay, but that wasn't the metric we've used the past few years, why move the goalposts?
Are we really saying that the only efficiency metrics that matter now are at 200W+?
gdansk
4,688
7,925
I didn't move the goalposts - Intel did in 2021 and AMD followed.
I don't know why Intel still feels compelled to ship only 160-250W CPUs with Arrow Lake where they are outside of their efficiency range afforded by lower platform power.
And at all power levels Lion Cove is less efficient than Zen 5 in SPECint despite being on a slightly more efficient manufacturing process. That's bleak. It didn't even achieve the main goal we were hoping for months ago after Zen 5% was revealed.
jpiniero
17,006
7,407
Because these are the K parts. There'll be "65" and "35" W models announced at CES.
adroc_thurston
7,887
10,614
Did Intel think Skymont would enough on client, so they got rid of it?
Pretty much yeah.
yeah, what a waste of N3b wafers.
Reactions: Joe NYC
DavidC1
2,021
3,157
So if Darkmont is a rather minimal upgrade as has been said, it's fair to expect Arctic Wolf and Golden Eagle (is that the first time this is mentioned?) to be big ones if they have to pave the way for the E core to take over the P core's duties after them.
Golden Eagle would also be the small upgrade.
poke01
4,606
5,916
The question is will unified core be enough to take on Zen7, M7 and CPUs from ARM?
With currant pace of E-core I would say yes.
alcoholbob
6,390
469
Do we actually know it’s less efficient? I haven’t seen any mainstream testing data except for nT performance at PL2.
The only graphs I’ve seen of a perf/watt curve shows ARL doing better in power limited scenarios in cinebench R23 & R24.
The main thing I noticed is 285K is way more efficient than the dual CCD AM5 parts in gaming. When 7950X or 9950X are gaming, the power consumption is around 110-120W range, double that of the single CCD parts. But the 285K can run games at lower TDP (usually 50-70W) while still being in a dead heat with 9950X in productivity.
DavidC1
2,021
3,157
I'm not so sure about that. If my measurements are correct Zen 5C on N3E is about the same size as Skymont on N3B but it has SMT too which helps quite a lot in certain workloads. So it seems to waste less die space than letting Intel design a CPU core.
That's for Turin Dense right?
I'm getting 1.9mm2 without the L2 cache using SP5 package size which is 75.4mm x 72mm. That's bigger than Skymont with 1MB L2. Without it, it's 1.15mm2.
DrMrLordX
23,114
13,215
But SMT has so many advantages and Lion Cove for server needs AVX 512 and AMX and other changes that they may as well add SMT too.
Intel isn't going to use Lion Cove in server, are they? Diamond Rapids is something else.
biostud
20,011
7,100
Just remember the efficiency of the 3D vcache chips are usually way higher than the non vcache. Hopefully that will also be the case for Zen 5.
H433x0n
1,224
1,606
Got it. Power scaling is irrelevant, the true way to measure efficiency is performance in the 200-250W range.
511
5,118
4,605
The DLVR Screwing around at higher wattage that is clear from derbaeurs video
DavidC1
2,021
3,157
DLVR is supposed to be energy efficiency at lower load and bursty workloads. It's a linear regulator so there will be losses at the high end. It's all described in the patent from years ago. You have two parallel regulators, so it can absorb the load better without much vdroop, so you can lower the average voltage.
DavidC1
2,021
3,157
Diamond uses Panther cove which is an update over Cougar Cove which itself is update over Lion Cove
Cypress Cove: 18%
Willow Cove: 0%
Golden Cove: 19%
Redwood Cove: 0%(arguably minus)
Lion Cove: ~10%
Based on this trajectory Cougar Cove is the 0% shrink and Panther Cove is maybe 10%.
Do you know Exist is saying that 20A was so bad that it would have resulted in a worse Arrowlake?
gdansk
4,688
7,925
It happens to be worse the way Intel ships it but I posted the SPECint graph a while back. It's worse across the entire range power range. And its performance per watt is worse across the Phoronix test suite too.
5,118
4,605
Cypress Cove: 18%
Willow Cove: 0%
Golden Cove: 19%
Lion Cove: ~10%
The same exist50 said about 8% for IPC for Cougar Cove he hasn't given any projection for Panther Cove
As for 20A I don't know how bad it was except for the fact that it is a money looser and something went wrong with it that is why it was killed.Intel is not in a position for bleeding money on one off node without any significant returns which 20A failed to deliver
Maybe i will create a reddit account just to ask exist50 the IPC gains for PNC
Kocicak
1,177
1,232
In my opinion it is enough for client. 285K, 9950X, 14900K all have more MT than 99.9% of people need.
Even a 14600K with HT turned off (14 threads) has more MT performance than 99,7% of people need.
It would be really unfortunatete if HT in the new CPUs was only turned off and no optimisations/improvements physical removal of this useless feature would allow were realised.
