Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 561 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
741
700
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4TSMC N3BTSMC N3BIntel 18A
DateQ4 2023Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P8P + 16E4P + 4E4P + 8E
LLC24 MB36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
FlameTail
4,384
2,757
Nah NVL will have both, specially if it uses N2P and increases core count. If the rumors of a stacked cache version are true, then they'll finally have a chance against Zen X3D, after 5 years of domination
NVL = N2P ?
Why not A16, which goes into mass production and has BSPDN (which N2P does not)?
Reactions: Tlh97
Joe NYC
3,030
4,426
Both Intel and AMD making a really strong case for me buying the M4 MBP for work related tasks and keeping my Raptor Lake system for gaming.
Why would you be making that decision about buying MBP before the first x86 based MBP competitor is released (Strix Halo)?
coercitiv
7,143
16,573
Probably because his issue is with the P core performance/efficiency, which he finds lacking from both companies. Strix Halo will not change that (even if it improves a bit).
Wolverine2349
466
154
86
Based on Lunar Lake info that was released by Intel at the time (whatever one might think about it).
That Arrow Lake gains vs. Raptor Lake will be smaller than Lunar Lake vs. Meteor Lake gains.
Some people expected same or bigger gains from Arrow Lake.
In gaming or all workloads or both?
If the gains are small in gaming but on par, its ok. Raptor Lake can trade blows with 7800X3D and beasts it in heavily threaded games when tuned right. Pity it has stability issues.
If Arrow Lake on par with 14th Gen in gaming with much lower power across it will be fine.
Wolverine2349
466
154
86
Because we already know M4 is better in almost every way outside of gaming and 512 bit vector operations?
Too bad its not X86 and has no where near the software library to run natively on it.
If it were X86 game over.
But no thank you emulation which has massive performance hit not running software natively at hardware level. Ouch.
gdansk
4,092
6,772
Switching from Windows to MacOS is not a trivial change. Neither is loss of ability to run software written for Windows.
It's a different issue. Presumably someone looking at a Mac is already aware the programs they need work. It doesn't work for you but it does work for me.
Joe NYC
3,030
4,426
Primarily in gaming, which tends to be the most memory latency sensitive.
Raptor Lake has better memory latency, which is how it can beat regular Zen 4, but Zen4 x3d hides the memory latency disadvantage of Zen 4 and then some. Which is how it come out on top in gaming.
Apparently, there is another issue (reading on Twitter) that Arrow Lake reduced ring bus speed. High ring bus speed is what caused Raptor Lakes instability and silicon degradation... We will see how much impact that has, vs. memory latency alone.
511
2,060
1,802
Mac/iOS don't care about comparability at all what runs today may not run tommorow they have the most flexible CPU Design Choices just cut the thing and make it
Joe NYC
3,030
4,426
Well, Strix Halo will have not 4 (like Strix Point or Lunar Lake), not 8 (like Arrow Lake), but up to 16 performance cores, and it also has HT.
So, for anyone seeking more P core performance, it would be plain dumb not to wait for the info on the strongest contender and make that sort of jump blind.
coercitiv
7,143
16,573
Why not? It has some cool power saving features and some cool performance enhancing features.
I think we all know better than to discuss Strix Halo vs. M3/M4 in the Intel ARL thread. @H433x0n made a remark, folks can agree or not with his take. If you want tot discuss it further... great place to start would be a dedicated thread for Strix Halo.
Doug S
3,139
5,384
You can run ARM Windows as a VM in Parallels, and Windows handles the x86->ARM translation. Unless the software you need to run on Windows is really performance sensitive, the translation overhead won't even be noticeable. Obviously this is a bad solution if your primary use for a laptop is running stuff that's only available on Windows, but if you have light/occasional needs for Windows only software a Mac would be fine.
There is no "loss of ability to run software written for Windows".
poke01
3,448
4,729
poke01
3,448
4,729
do you have proof of this happening in the last 4 years? I mean if Apple didn’t care about compatibility they would have never supported x86 translation layer in their arm64 version of macOS. They even expanded support to include AVX2 extensions and gave Linux VMs the ability to use this translation layer. Docker also works with x86 containers, something the X Elite can’t do yet.
but yeah they also drop support for 32bit apps which sucks. That’s why it’s good to have a MacBook as a backup. Windows will be king always due to the software backlog tho especially for gamers and engineering.
