Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 497 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
719
674
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4TSMC N3BTSMC N3BIntel 18A
DateQ4 2023Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P8P + 16E4P + 4E4P + 8E
LLC24 MB36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
coercitiv
7,111
16,451
Indeed, and it is good at what it does. But I have seen little info about it since SNB, I know it does h264, and I think h265. But AV1? Not so sure,
I use Wikipedia to keep up with encoding/decoding from the usual suspects - Intel / Nvidia / AMD
AV1 encoding is available in Arc GPUs, Meteor Lake and probably the upcoming ARL as well. I would assume Lunar Lake has it as well.
Reactions: SiliconFly
mikk
4,287
2,370
Shader assisted encoding from the GPU can be a little more flexible with somewhat better quality but wasn't big really and much much slower. Intel dropped GPU assisted encoding with Arc GPUs for this reason, it didn't make sense anymore. It's a fully fixed function encoding and quality improved at the same time. And nobody should use SB or IVB as a measure against hardware encoding because it hugely improved over the generations. Lunar Lake gets a new media engine, maybe it's even better there. Battlemage dGPU unfortunately doesn't get the new one from Lunar Lake.
MS_AT
594
1,242
Great post. Can you clarify this paragraph a bit more? Was the mistake that E cores didn't have AVX512 or that AVX512 was not correctly developed upon inception?
From E-cores point of view it would be better if AVX512 was introduced the same way that Intel plans to do with AVX10 now as that would make it more likely for them to implement them on the space constrained cores and wouldn't force them to drop AVX512 compatibility. But it is easy to say now, I guess no-one thought 7 years ago that Intel will need to do E-cores in mainstream on the inferior process.
Generally though I believe it would have been best if they handled it like AMD did with Granite/Strix. Mobile is still ISA compatible but has lower throughput. Skylake could have also been ISA compatible with Skylake-X but just double pump the execution units with smaller register files etc. This solution is better as you don't have to recompile your code. Just move the binary from Intel Core to Intel Xeon and enjoy the speed-up. But management wanted to make AVX512 a premium feature and now we see how it panned out. Not to mention they are slow learners as they wanted to sell licences to enable accelerators on Sapphire Rapids not so long ago, fortunately this idea went to the bin.
naukkis
1,004
844
Intel QuickSync is a decicated hardware block that has nothing to do with the GPU. Starting MTL, it now resides in the SoC tile I think.
Qs as other media cababilities are part of GPU media properties. MTL gpu is split design, shader and raster engine is in their own tile, rest of gpu including display controllers with media properties are placed on soc tile.
LightningZ71
2,127
2,568
Could Intel even feed AVX512 instruction streams on Arrow Lake if they had enabled it on both the P cores and the E cores? That's 24 cores all pushing very high throughput demands against 128 bits of DDR5. I suppose if they did 256 bit datapaths with double pumping, it wouldn't be too mismatched.
gdansk
4,069
6,729
I would presume P cores would do full rate and e cores half rate. Effectively the same bandwidth requirement as 9950X. And unlike AMD it has a memory controller more equipped to feed it.
Of course it's all imaginary since Intel didn't go that route. But had they I think it'd be even better.
MS_AT
594
1,242
Even if it would be half rate on both, it would be a clear signal for software developers that it's worth to pay attention. Especially if the E-cores only CPUs would keep it, so it wouldn't be like Atoms of old, that were limited to SSE only for a very long time.
mikk
4,287
2,370
Yes. The Media Engine is in the SoC tile, but runs independently of the GPU tile. While running, it doesn't require the GPU tile to be powered on.
From AT:
"Starting things off, we have the Xe Media Engine, which is embedded within the SoC tile. Within the Xe Media Engine are two Multi-Format Codecs (MFX), designed and responsible for all the encoding and decoding tasks. Intel's Meteor Lake with Xe supports the latest codecs ranging from AV1 (decode and encode), HEVC, AVC, and VP9, with up to 8K60 HDR decode supported. For encoding, there's support for up to 8K resolutions with 10-bit color and HDR. Aiming to improve power efficiency on-chip with encode/decode workloads, having a dedicated Media Engine separate from the graphics allows Intel to find granular power savings as things are directed to the Xe Media Engine, which means the graphics tile doesn't need to be powered up to accomplish encode or decode tasks."
Prior to Arc graphics media engine had two modes, one was a hybrid of GPU+fixed function engine and the other a fully fixed function engine encoding mode (sometimes called low power mode). MTL or any Arc based graphics only support the full FF engine encoding mode which is much faster and power efficient.
LightningZ71
2,127
2,568
Since Intel has a history of having consumer cores and xeon cores differing on AVX512, it's not far fetched to see the P cores being either half OR full rate on consumer dies. To keep die sizes manageable, and offer differentiation with xeon dies, it would make sense for consumer died as half rate.
DavidC1
1,442
2,346
The extra registers even doing 256-bit mode still costs quite a bit of more transistors apparently.
Since it was a misguided idea in the first place, there can't be a clean way of resolving the issue.
OneEng2
504
736
So I have a couple of questions on the up-coming Intel CPU releases.....
One, I originally heard that Intel would be making the CPU tile on their own 20A Intel process. Most recently, I hear they are moving that to TSMC .... which I am guessing would be their N3E or N3P. I am not clear on the proposed density improvements of N3P over N3E, but my guess is it isn't drastic (say 5%).
Lets say that Arrow Lake is being produced on N3E. It looks like Arrow lake is 4% faster single core and 14% faster in multi-core than AMD's 9550 (according to the latest leaks I can find).
So, sounds good but .....
Arrow lake is boasting a 24 core processor against a 16 core processor. Sure, ZEN5 has hyper-threading, but I believe the last time I did some numbers, it is really only good for about 20% (in multi-threaded apps).
So all things being equal, an AMD Zen 5 core is worth 1.2 Arrow Lake cores ... or 19 cores.
So overall, Arrow lake utilizing a process node allowing 1.5x the number of transistors of Zen 5 is getting14% higher multi-core performance using a node that is considerably more expensive (N3E I think) than Zen 5 (N4P).
I have a feeling that AMD's memory controller and IO for consumer are likely limited to 16 cores at this time. Otherwise, 2 more cores would bring a Zen 5 up to par with the Arrow Lake.
A die shrink for AMD to N3E seems like it would more than put the next AMD processor ahead on all fronts.
So will Intel still be beading red after Arrow Lake? Will AMD just lower prices on their less expensive processor and force Intel to give up profit?
I am also not sure about energy efficiency, but I am excited to see the detailed reviews on Arrow Lake when they come out. This will be the first time EVER that we will be able to compare Intel and AMD designs on an equal process node (when AMD makes the shrink to N3E).
I have been following processor design between AMD and Intel for decades. I have always thought that Intel's biggest advantage was the fact that they always had 1.5 to 2 times the transistor budget as AMD at any given point in history.
It is now starting to look like that advantage will be erased. Interesting times.
Josh128
758
1,261
Lunar Lake is on N3B. Arrow Lake is likely on a higher performance variant of N3. Lunar Lake should make much more money for Intel than Arrow Lake, being that its going into premium laptops that command higher margins and is a lot less silicon area than Arrow Lake.
Arrow Lake will likely be expensive, so I have my doubts AMD will lower Zen 5 desktop prices due to Arrow Lake. Zen 5 desktop is AMDs second least profitable business, only consumer /desktop GPU is less profitable. They would rather sell the silicon in EPYC, Instinct/MI, or laptop at higher prices than sell desktop at lower prices.
511
1,840
1,676
Leaked Excel Sheet from the file looks Interesting Cougar Cove and Panther Cove for Noval lake iirc Cougar is 5-10% IPC Increase while Panther is double digit over Cougar
[ Not a leaked roadmap]
