Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 480 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
695
601
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (20A)Arrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4Intel 20ATSMC N3BTSMC N3BIntel 18A
DateQ4 2023Q1 2025 ?Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P6P + 8E ?8P + 16E4P + 4E4P + 8E
LLC24 MB24 MB ?36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
SiliconFly
1,532
882
On single thread, the 285K will be ahead. Looking at computerbase, the 14900K was 9% ahead of the 7950X. I don’t think it’ll be ahead by nearly that much. I said 0-3% before, I think it’ll be around that 3%. In multithread the 7950X was level with the 14900K. I think the 285K will at least be equal again.
3%? :fearscream:
Compared to AMD HX 370, Lunar Lake 288V is already ahead by around ~15% in ST perf I think.
Same should translate well for 9950X vs 285K in ST perf. The difference should be in excess of >10% to 15% easily. My guess is ~15%.
It's a common trend I'm seeing with many people here. They're still not able to accept the fact the Zen 5 doesn't have a good IPC uplift this gen and has fallen below expectations. It has underperformed.
Whereas, Intel this gen has shown good performance uplift thereby widening the gap more than it should.
Meaning, the perf difference between previous gen and this gen is gonna be more. A lot more!
Reactions: lightmanek
jdubs03
804
411
Intel's benefit this time is that they can count on real physical cores and not be hampered by HT related issues dragging down performance. I think you should brace yourself for 9950X losing in some benchmarks because SMT cannot match a real core. I just have to call it like it is. Intel has a slight advantage this time around. Well, until AMD boosts 9950X performance with an AGESA update or something. I would've preferred 9950X having CCD2 comprised of 16 Zen5c cores.
I don’t know why my post was ignored (not by you obv). It was very even handed. I’m not playing favorites.
Even in single core, we ll see in a month when they release ARL but given the gap between the 9950X and the 14900K i doubt that it can be closed given the improvement in CB, as with other renderers it will start from a lower step.
FTR the former is 21% faster in Blender, 30% faster in Corona, 51% faster in V-Ray and only 5% faster in CB 2024, wich by those number is the convenient exception used as a rule, the geomean average of those 4 numbers, 25.6%, is way more representative than an outlier.
As you can see it require a much better ST perf to get those numbers given that SMT bring a comparable gain for all tests.
In single thread you’re basically claiming the 9950X is going to be even to ahead of the 285K (pulling back that 9%) when all of the data out there so far says this isn’t going to be the case.
3%? :fearscream:
Yeah I’m trying to be conservative. In CB my guess is it will be 8–9% higher, but I think the other benchmarks will be lower single digits.
The 288V won’t be much higher (maybe a few %) in GB I don’t think just going based on their releases so far. But for CB it’s somewhere around 12%. Time will tell to fully confirm those and other benchmarks.
(I think AMDs desktop core is more competitive than their mobile in ST)
511
404
260
Single core avx-512 will be the only win for 9950X vs 285K
Corona/vray uses intel embree which has avx-512 support so there is that as well blender doesn't support it and we are expecting 15-20% mt improvement so blender would be within 1-2%
Abwx
11,536
4,324
What are all thoses tests, Cinebench.?.
In the GB ST submissions ARL is not ahead even with 7200 RAM, from the few leaks it s neither ahead in WebXPRT4 wich is tailored by Intel and is single threaded, nor in Speedometer 2, only in CPU Z, lol.
Abwx
11,536
4,324
Cinebench R15/R20/R23 all use Embree as well.
jdubs03
804
411
No it’s this:
You got one leak for at best a QS 2-3 months away from a final product. Both Zen 5 and Lion Cove are around 15pct higher in IPC and both have a clock speed reduction of 5%. I don’t see how Zen 5 claws back a 9% gap with those numbers.
Reactions: Josh128
Abwx
11,536
4,324
No it’s this:
The 9950X has on average 11.57% better IPC than the 14900K in this graph, wich is duplicated by GB 6 wich is exactly on the average, and so far there s GB submissions where ARL is no better than the 9950X in ST.
Other leaks for WebXPRT, Speedometer or even Cinebench just go in the same direction given that the tests frequencies or power were stated, it s not like it was some hasardous ES clocking randomly.
jdubs03
804
411
I’m just saying; going by the information provided by each company. The numbers align with Intel being slightly ahead on single thread. For the prior generation Zen 4 was quite a bit behind, I’m acknowledging that Zen 5 has bridged some of the gap, but I don’t think they’ll bridge all of it. I think that is too much of a stretch.
cebri1
348
371
According to Guru3D, Z5 has about an 10-11% IPC advantage over RPC.
LNC mobile has 14% IPC advantage over RWC, which has a similar IPC to RPC.
It's really a matter of clocks. In ST if LNC desktop is anywhere near 16% IPC over RPC, and can indeed clock to 5.7 Ghz it should take the ST crown. MT is a different story because of the lack of HT, so chadmont will need to show its value.
At the end, both processors will have its weaknesses and advantages and the consumer will be able to choose the one that fits more its needs.
Josh128
350
478
According to Guru3D, Z5 has about better 10-11% IPC over RPC.
People have to remember that the removal of HT only applies to the P cores, the E cores never had it to begin with-- its not that much of a negative. So, assuming +25% average MT on the Raptor Cove P cores in MT w/ HT, Lion Cove 's 8 cores, with their +14% IPC uplift, will see a net 11% reduction in MT for P core cluster. Meanwhile, the 16 Skymont cores, with ~+38% IPC over Crestmont.
P-cores only get about 22.5K in R23 at stock (correct me if Im wrong). Take 11% from that and you get ~20K. E-cores add about 18K for a total of ~40K. Take your new 20K for non-HT Lion Cove cores and add to it 24.85K (1.38 x 18K) and you get 44.85K. The biggest assumption here is that the +14% IPC for Lion Cove and +38% for Skymont figures given apply directly to CB R23. If they do, you are going to end up around 44.9K in R23 MT. Simple as that. Thats +7.4% stock vs stock 9950X.
I think the above is actually a bit conservative. My prediction was ~+13% MT average over 9950X at stock, and I still stand by that. So the R23 score could easily end up around 47K stock for 285K.
naukkis
895
773
Performance is ipc*clocks. Arl will also clock it's e-cores higher than rpl. +100mhz from 14900ks and 200 from k. P-cores clock will also vary by amount of power budget left - at sane power limits arl should clock its p-cores higher too. So there might be good amount of mt power coming - if they can sustain those clocks.
FlameTail
3,857
2,298
ADL-N spiritual successor. So <$500 - 400 laptops.
2P + 0E + 4LPE Cougar Cove + Darkmont
2 Xe³ Cores (256 ALUs)
20 TOPs NPU (?)
64-bit memory bus (?)
If 20 TOPS NPU is true, that means it won't even support Copilot+ 1st gen (minimum 40 TOPS).
And by that time in 2026, Microsoft would have unveiled Copilot+ 2nd gen (minimum 80 TOPS?).
Does Microsoft not want to bring Copilot+ to the sub-$500 laptop segment?
cebri1
348
371
It's a chrome book, you also need you differentiate your devices. If the consumer wants CoPilot+ they'll need to pay more.
