Page 474 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
There have been a lot of recent members using this same line. Curious coincidence I'm sure.
"Intel has nothing to worry about."
He calls this nothing to worry about. Its getting creamed. One of my 9554's almost is equal to TWO 8592+'s !!!
Quote from the article number 1 (I will look for more
"At this point, a few things are reasonably clear. Intel does not have the core count to go toe-to-toe with AMD in this generation."
Apple sells about 15-20% of worldwide unit sales. Profits are much higher. The opposite with Intel, server marketshare higher and profits lower when compared to the competition. Not great.
Apple sells less phones, well it’s still a lot but less then others at around 150-200 million iPhones sold every year.
But since most phones they are in the $700-$1200 range they make a lot of profit.
Intel also sells the same amount of products in client.
Yea, because they have a core count deficit. That disappears with Granite Rapids. Even if I don't believe they won't take #1, they are probably going to be only about 10% or so away, the best position in servers since Skylake.
If you let your bias influence your decisions, you'll constantly be wrong.
And the 9554 equalling 2 8592's ???? Core count there ? And wattage ? I don't see any actual numbers there. But 2 8592s vs one 9554 ? I doubt they have less.
According to that very chart, 60 core 8592 is beating 64 core 9554. EPYC 9554 is also 360W, similar to 8592. And they are both dual sockets.
Like I said, you let your bias influence your decisions, then you are going to be constantly wrong. You have to go solely by data.
I think you may be misreading this.
It shows Dual 9554 EPYC (2x64C, 256 threads) vs Dual Platinum 8592+ (2x64C, 256 threads) being close in Linux compile times with the Xeon slightly edging ahead.
Unless you mistyped and meant 9654 EPYC but a single socket 9654 isn’t in this chart.
Edit: fixed core counts
It shows Dual 9554 EPYC (2x64C, 256 threads) vs Dual Platinum 8592+ (2x60C, 240 threads) being close in Linux compile times with the Xeon slightly edging ahead.
8592+ is 64 cores.
8592+ is 64 cores.
I stand corrected.
It's still beating the 64 core EPYC. 128 core Granite Rapids will be very competitive.
Intel has good products coming, which markfw can't see. But that's not Intel's problem. The problem is they are basically a finance company and will fall flat in engineering again.
You are right I did not see dual both places. But I would like to see actual wattages. My 9554 @%100% is running 282 watts. What is the 8592 REAL actual ?
Average power 2P 8592+ 556W.
Average power 2P 9554 377W.
And the 2P 9554 still 3.6% ahead in the perfs average, that s the data.
So that s RPL transfered to the server area.
Bias influence you said.?...
Phoronix reviewed the CPU as well, here was the min and avg power consumption measurements across the full test suite:
Min (W)Avg (W)
Dual Epyc 955425.64377.42
Dual Xeon 8592+100.34556.83
With GNR being on Intel 4, we should expect a significant drop in per core power consumption.
I let this speak for me..... But my point still stands. Intel DOES still have something to worry about. And Turin is not out yet......
No one said Intel will be a leader but it'll be much closer this time, within 10%. That's the whole point. SPR is their weakest point in servers.
Now THAT I agree with. If power was competitive, then AMD WOULD have to worry, due to Intels big installed base lead. Power is still a problem, and in the data center, 10 times more than desktop.
I wonder if in the next generation after LionCove we will see a 10-Wide, 8x ALU and 6x FP decoder, or maybe Intel will immediately switch to a 12-Wide, 10x ALU and 8x FP decoder.
GNR is on Intel 3.
Yes also Intel 7 -> 4 -> 3 is approx 1.20*1.18 = 40% PPW ON A best cae even with no ipc it should improve by 40% ppc best case btw redwood cove on Intel 4 has 20% PPW vs 13700H p core
People get real nervous when there are any chances of good competition between the two. I though that was good for consumers.
Let me try to explain again. After all the lithography steps are taken for a given EUV layer the wafer can be optically scanned for defects. The statement is that if 3 hours are spent performing that optical scan and no defects are found, that optical scan only provides confidence that there are no defects in 62-63% of the 1cm^2 die. If less time was spent on the optical scan the confidence rate would be lower. More time spent would give a higher confidence rate. It says nothing about actual Intel 3 defect density.
So then what was the value of this observation in the first place, that people would see fit to distribute the information? Do we have any reference data from other EUV nodes for comparison?
@Markfw
Phoronix has a pretty good review of Emerald Rapids you can use for reference if necessary:
Draw your own conclusions from that.
@Hitman928
Indeed those products weren't even listed for sale a few hours ago. At least now one outlet is selling Sierra Forest!
Within 10% in AVX-512 workloads too?
I think Intel saw that threat incoming and embarked on the AMX bandwagon. At least on that front, they have nothing to worry about.
