Page 463 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
It's not an excuse for advertising an unfair comparison, but in which scenarios would you actually be running AI workloads on the CPU, when you have an NPU and GPU available? Seems counter productive both in power consumption and performance.
LPDDR has higher latency. LNL I believe uses LPDDRX which may account for some or most of the difference, not sure.
The packaging should also bring latency benefits I guess. I mean memory is on package, doesn't need to go through motherboard PCB. It's physically much closer to the CPU than otherwise would be possible.
The latency added by the additional distance is insignificant. You may get a small benefit if you don’t have to buffer as much due to the close proximity and reduced parasitics.
That result is from a top secret subterranean lab. The message was delivered via note slipped out through a guard and a brave individual risked his life, trekking over miles of rocky terrain littered with hungry hyenas and venomous critters to make the post possible. Go easy on him!
Hyenas on rocky terrain. I MUST BE TRIPPIN.
Everything else checks out that though.
But its really strange to me that these mobile chips have so high latency compared to desktop, this is one of my old runs on regular Zen5
(on latest tune i haven't made made public yet, i'm sub 74ms)
LPDDR has higher bandwidth but worse latency than DDR. It is difficult to find CAS latency values for LPDDR5, but if the CL was 39* instead of your CL of 32 (22% more latency), that would explain all the difference. Here is Anandtech's article on it (which was copied from another article since even Anandtech didn't have permission to download the JEDEC timing standards).
Extended Latencies - LPDDR5X SDRAM devices support extended Read, Write, nWR, ODTLon and ODTLoff Latency Values to account for longer number of cycle it takes to do the data access to memory array.
* There is an AI page that you can find that estimates CL40 for LPDDR5, but I didn't find that credible enough to put too much emphasis on it. I'll just leave this as an IF statement: if the CAS latency is 39.
LPDDR5X-7200 can work at CL28 in CAMM2 form factor: https://www.tomshardware.com/pc-com...tosses-expert-ai-branding-in-for-good-measure
Seems Intel could be keeping costs low (for themselves) with lower quality on-package RAM?
That would work out to be, what, CL34 at higher frequencies?
I don't really know what the latency is for Lunar Lake. But it is possible that Intel is going with cheaper (and/or more available) higher latency RAM rather than cutting edge RAM. My point is just that people posting above can't claim the latency tests are wrong when we don't even know the latency of the memory being used.
Looks like some machines are popping up for purchase
They can't ship until another 20 days however.
I am curious if these machines with bright high refresh rate OLEDs end up getting poor battery life even with an efficient SOC. Seem like pretty power hungry displays.
At least they have priced the 32GB laptop relatively reasonably.
Yikes! You think 1,500/- for a Lunar Lake laptop is reasonable? Sounds a bit expensive.
Better than what Dell is charging for their 16GB slower one.
And ASUS will discount it after a year or so (if they overproduce 🙂 )
I see them selling old stock Tiger Lake at below $200 on their local online store (UAE).
Tiger Lake for 200$ is still a very good deal imho. Pretty decent performance.
I was MOST tempted to get it, but then I already have a "Ice Lake laptop turned mini desktop" that I bought from a 15 year old kid, one 17 inch HP Tiger Lake 32GB RAM laptop that I use for Teams meetings and one Ice Lake 8GB LPDDR4 laptop because the price was too good at something like $190 (plus it came with a stylus!).
