Page 428 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
926
844
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
5,170
4,632
DavidC1
2,023
3,161
Unfortunately it’ll probably end up being +5% 1T and +15% 1T and be basically tied against Zen 5 and launch to a flurry of negative reviews and x86 doomer talk.
14900K is 6GHz ST so, assuming 90% clock scaling 14% better uarch results in 5.7GHz Arrowlake being 9% faster.
15% MT is realistic for average since Lion Cove loses HT and if you assume 2 E cores = 1 P core in Raptorlake generation. Maybe 20% is possible since Skymont clocks slightly higher than the "Raptormont" core. This assumes 50% average gain for Skymont with a combined Int/FP application and being 30% faster in Int and 65% faster in FP.
Worst case scenario, in MT Int it might be 6-8% faster.
What defines a "flop"?
Failure to meet wildly unrealistic expectations?
Zen 5 offering 32% may have been too much but Snapdragon Elite at least looked promising based on initial specs. It didn't live up to the projections in their own slide, so they lied or missed quite a bit.
While Apple's gains are lot less than before, they are coming from an absolute leadership over x86. So the fact that both Zen 5/Lion Cove is under historical 15-20% gain is a disappointment.
There's no particular reason to expect it should be so far behind the ARM cores either such as the embarassing ST perf/watt difference.
jdubs03
1,367
952
I think we should expect to see around a 12-15% increase in multi thread for ARL. It’d be nice if there was a 9% improvement in single thread, but I feel like it’s gonna be more like 2-5%.
It’s a shame because I feel like they had an opportunity to come back pretty strong against Zen 5. But if they’re gonna be able to limit the power significantly (rumor has it consuming 100W less at peak performance level), and we see that in the benchmarks, then it won’t be so disappointing.
Since it’s directly relevant to this conversation, I’ll just leave these two here as a reminder of what the expectations are for ARL. I know we’ve all seen it, but doesn’t hurt to repeat it.
Reactions: sgs_x86
coercitiv
7,448
17,754
I think @H433x0n 's take is still within the realm of possibility, even if leaning on the pessimistic side. The 14% figure was given, as you already know, for uplift versus Redwood Cove in Meteor Lake. AFAIK RWC showed some PPC regression even against mobile Raptor Lake.
Here's some SPECint 2017 result for example, since integer is Zen's weak point moving forward. Even if half the regression is due to different memory subsystem used on RPL system, we'd still be looking at a potential 4% penalty. Combine that with your estimate of 9% perf uplift and we get closer to the 5% mentioned by H433x0n.
H433x0n
1,224
1,606
That data seems out of date or weird. In the past month there's been multiple reviewers that had MTL ahead of Zen 4 in Specint when at a fixed 4ghz. I don’t remember seeing a similar comparison for RPC v Zen 4 but I doubt it did much better than RWC. Below is geekerwan's data, there was another reviewer that got the same results too that I'm trying to find.
David Huang got similar results when he compared RWC, Zen 4 and Zen 5 at a fixed 4.2ghz.
Point being, I'm not sure if RWC is a pure regression in IPC.
Reactions: Tlh97 and ikjadoon
coercitiv
7,448
17,754
Be that as is may, I only took less than half of the regression in that table into consideration. David Huang's initial data showed just under 9% regression, I took 4%. That would put RWC 2.4% ahead of mobile Zen 4, which aligns with geekerwan's data and exceeds the advantage shown in David Huang's later Spec test with LPDDR memory for all CPUs.
Let me ask you this in return though, how did you arrive at the 5% ST advantage scenario (even as a worse case versus the possible 10% option)? Was it just "Intel will mess something up" and drop 5% in the process?
TwistedAndy
159
150
H433x0n
1,224
1,606
There are some new Geekbench v5 and v6 results for Arrow Lake:
It looks pretty nice.
The GB5 score is good and would put it at 2500-2600 range. The GB6 score is mid but would still put it on par with Zen 5.
Have to see if there’s any improvements with more mature BIOS and microcode.
511
5,170
4,632
If user can have 10-15% Better MT 5-9.69%ST vs 14600K while consuming only 125W vs 181W it would be a nice upgrade also GB is nice but doesn't tell whole picture even GB6 ST is going to be a meme
vanplayer
66
You would like to repeat it in the future. These 1 year old slides exposed what Intel could do in the next 3-4 years, count from leaking date July 2023. Guess if Intel could survive until then.
eek2121
3,464
5,118
That is going to depend on power consumption. Leaks that came out over a year ago indicate it should be competitive with Zen 5 in terms of performance/watt, but we will see. Things change. If they actually outperform AMD in 1T/nT workloads and also manage to keep power consumption in check…shoot I might be going Intel.
EDIT: I am surprised that after remarks made by Intel, they didn’t enable SMT. Now they have a thread handicap, but as you can see, that doesn’t matter! 🤣
511
5,170
4,632
Geekebench doesn't scale with threads also we didn't knew about ChadMont
Wolverine2349
525
179
86
How good will latency be on Arrow Lake.
I know now on a tile instead of monolithic die, but isn't it monolithic on a tile instead of 10nm? Like
So wouldn't it still be much better than AMD chiplets because its a ring bus on the tile and all cores on ring bus and Intel designing it like that? So could latency be as good as the 10nm Alder and Raptor Lake?
dullard
26,185
4,844
Thanks. I always need to compare them to other CPUs since I don't memorize scores on various benchmarks. Here is Videocardz' take on it (with the obvious grain of salt of not knowing necessary details of the platform like power consumption):
Going by that chart: this mid-range chip is 9% faster ST and 1% faster MT than the comparable 14700K. The single thread performance is on par with what the Intel leak claimed (posted by jdubs03 a few posts above). But the expected 6% to 19% MT performance gain isn't there yet.
9949asd
139
GB6 only can look at st. The MT for x86 is always not right.
MarkPost
378
794
Geekbench v6 results for Arrow Lake:
Not good to say the least.
That 265KF compared with my 13900K (Intel extreme profile and DDR5 @5600):
ST: 265KF 4.3% faster than 13900K
MT: 265KF 2.5% slower than 13900K
Hitman928
6,750
12,479
Wolverine2349
525
179
86
ST should be 8% faster with fastest ARL (5.7 GHz). Of course, the difference will be smaller if compared to a 14900k (<= 5%).
Yeah looks like another underwhelming uplift.
Though its welcome because stability is needed and the 8 + 16 RPL die has stability and degradation issues that no microcode update can fix IMHO and gut feeling!!
Wolverine2349
525
179
86
Not good. Though if latency is still good, its a welcome uplift as Raptor Lake was good if only it were stable and did not degrade so easily.
SO Arrow Lake fixes that.
Zen 4 is stable so Zen 5 underwhelming or no performance improvement in general consumer workloads and gaming is bad because Zen 4 is stable and does not have degradation issues.
Though hard to believe MT would regress. I know Arrow Lake has no HT but isn't the e-cores Skymont supposed to be so much better than Gracemont that it should easily more than make up for it given that HT is not a real core. Like isn't Skymont supposed to have IPC and latency of Raptor Cove or maybe 2% better or is that just wishful thinking?
