Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 192 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
820
785
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
TESKATLIPOKA
2,696
3,260
And no Armoury Crate. Lenovo Vantage is optional, whereas AC finds a way into your system.
I find Lenovo Vantage pretty decent and didn't uninstall It. If I need something I start It then close It.
Just be aware that USB-C ports can be misaligned, at least I have this problem, but they are still working fine, just a visual defect.
cebri1
373
405
We still need more test to confirm new pcode situation (if confirmed new BIOS includes the update) but also the new GPU drivers which should fix the abysmal drop in performance of the iGPU when going under 30W. If Intel manages to fix those things, MTL will become a very interesting product for 24.
TESKATLIPOKA
2,696
3,260
A decent product, but for 2024 the interesting products should be the next gen -> Strix Point and ARL.
Although not so sure what to expect from ARL, because from leaks It doesn't look like a big IPC increase can be expected and who knows about core count. At least with Strix we have 50% more cores and >>10% IPC gain.
cebri1
373
405
Those are going to be 2H products for sure. Probably Q4. Lunar Lake is in my opinion more interesting than ARL-H.
TESKATLIPOKA
2,696
3,260
Yeah, we will have to wait for them to be released, but performance uplift will be significant.
Lunar Lake will be interesting for It's efficiency, new IGP and maybe 1T, but I am not sure how good It will perform in nT thanks to only having 4P+4E+2LPE.
cebri1
373
405
I would add on-die DDR5, which should improve iGPU (and inference) performance a lot.
TESKATLIPOKA
2,696
3,260
How would that improve It?
It's just 16-32GB 8533mbps LPDDR5 on package. It won't perform better than If It was on board. Any performance gain will be because It's faster.
Reactions: Saylick
cebri1
373
405
I would expect a wider bus and an increase in effective bandwidth. If not... why move the RAM to the chip?
At least that is what I interpreted from the leaks
TESKATLIPOKA
2,696
3,260
With wider bus you can't have 16 or 32GB unless It's 256-bit instead of 128-bit. That 128EU IGP doesn't need that much BW, It would be enough even for 256-320EU IGP.
The reason why It is moved there is because It saves space on the motherboard in my opinion and probably a bit of power.
FlameTail
4,384
2,761
Pros of on-package LPDDR:
1. Space savings : You don't waste a ton of space on SODIMM/CAMM2 slots.
2. Power savings : Shorter traces can reduce power consumption (slightly).
3. Cost savings : Shorter traces and not having DIMM slots gives cost savings to laptop OEMs.
4. Performance improvement: Having the RAM closer to the processor reduces the trace length and in theory should reduce latency to RAM.
Cons of on-package RAM
1. Non-upgradeable.
mikk
4,293
2,382
NBC measured power at the wall with the internal screen disabled, the laptop hoover at 83-85W at the start of Cinebench, you think that a laptop that pull this amount of power has a CPU that run at a fixed 28W..?..
I gave the wrong link, here the correct one: https://www.notebookcheck.net/Intel...-convinces-with-GPU-performance.783320.0.html
They set a fixed TDP to 28W, 35W, 45W in a special Cinebench R23 scaling test, your quotes are not related. They can't set fixed power limits on the wall and they refer to the TDP, it is not a power wall measurement.
mikk
4,293
2,382
ARL-H and Strix Point will be 2025 contenders and Meteor Lake is a 2024 contender. Yes even if they are launching it at the end of 2024 or let's say Q4 it's similar to MTL. On AMD it usually takes a much longer time bringing them out into the market after the launch.
As for ARL-H the worrying thing is that hey are reusing the Soc and tile layout with all its flaws. Also the tGPU will be largely reused (slightly updated Alchemist). Lunar Lake is a real next gen Soc but this is limited to 4+4.
Reactions: Exist50
Abwx
11,868
4,846
I saw this curve, they made a mistake because there s no power/frequency curve that can be convexe like this one, all are inherently concave, that is, perf/watt decrease as power increase while here it s the contrary between 35 and 45W.
It s biaised because the turbo is working and shift the measurement.
From 35W to 45W the score increase by 20.6%, that s impossible as 20.6% higher frequency require something like 50% more power, the theorical best case with perfect mosfets that do no exist would be (1.206)^2 = 1.45x more power for such a frequency uplift.
At 45W it should score about 13500 pts assuming the number at 28W is accurate.
mikk
4,293
2,382
At 45W it should score about 13500 pts asuming the number at 28W is accurate.
Scores are too low, there is no turbo involved. By setting a fixed power number there is no PL2 involved, this the purpose of such a scaling test.
MTL seems to scale quite good with the power yes, even though it might got a little screwed because of the pcode issue. It is even worse in GPU benchmarks below 25W which is partially a driver issue says golden pig. I would not draw a conclusion at the moment, it definitely needs the pcode update and driver update for GPU benchmarks as well.
Abwx
11,868
4,846
Whatever the way it scale it power cant scale quasi linearly from 35W to 45W like in this weird curve, power increase at least as a square of frequency, moreover in this range where the uncore power is no more significant, i m talking of CPU perf for the time.
So if the power/frequency curve is convexe or even linear it means that data acquisition was flawed, we ll undoubtly have confirmation once commercial and final models are released.
TESKATLIPOKA
2,696
3,260
But a mix of Zen5 + Zen5C.
So the core count increase alone will not necessarily bring a 50% MT uplift.
It's not a problem that It's a mix, because the core is the same, only V/F curve is different, but It's actually advantageous for limited TDP as @coercitiv posted.
The only question is how big an uplift you will get at lower power limits.
1. Space savings : You don't waste a ton of space on SODIMM slots.
1. Non-upgradeable.
LPDDR doesn't use DIMM slots, the memory is soldered on board.
Reactions: Tlh97
TESKATLIPOKA
2,696
3,260
no LPE cores, just 4+4 it looks like
You are right, I mistook It because somewhere on this forum was a debate about It, but I didn't pay much attention to It.
From diagram It looks like only P and E-cores.
SiliconFly
1,924
1,284
Aligns well with the twitter leak. Actually there are no E cores. It has 4 P cores & 4 LP E cores.
