Page 128 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
inf64
3,884
4,692
FYI, Arrow Lake has a significant drop in power consumption. From recent leaks, it is more efficient than Zen 4. PL2 is said to be down to 177W.
If that 5%/15% is over Raptor Lake Refresh, that puts the chip well ahead of the competition in terms of both absolute performance as well as perf/watt.
Intel is also said to be launching Battlemage GPUs.
Will Zen 5 bridge the gap? Probably. I stand by my performance projections. Zen 5 and Arrow Lake will be extremely close in terms of performance. I won’t speculate perf/watt competitiveness, because there have been claims Intel is using TSMC for some parts, and that muddies the waters. I suspect Intel may end up with a slight edge, but we will see.
I will be considering Intel for my next upgrade if these rumors turn out to be true.
Computerbase ,with their very questionable choice for ST benchmarks (no spec, no Geekbanch; using two different versions of the same CB tool), has 13900KS ~11% faster than 7950X(3D). Expreview has it at what I think is correct value of 102.1% for 13900KS and 95.5% for 7950X - this is ~7% advantage for 13900KS. This is basically the same as what the 14900K (6Ghz max boost) should achieve.
Add ~5% on top of ~7% (1.05x1.07) and you get ~12% advantage for Arrow Lake in ST versus 7950X3D.
Gaming wise, Computerbase has 7950X3D at 9% higher average fps and 5% higher frametime values versus 13900KS. Expreview has no gaming data, but 3Dcenter has a nice average breakdown (here). 7950X3D is ~3% faster than 13900KS. If ArrowLake is only 5% faster than 14900KS in gaming, then it might just edge out slightly the 7950X3D.
As for MT performance, Computer base has 7950X at 2% faster (X3D variant is 5% slower ) vs 13900KS. Expreview has 7950X at 2% faster than 13900KS, while X3D variant is ~5% slower.
I assume that 14900K might be ~5% faster in MT than 13900KS. Add ~15% on top of those numbers : 1.05x1.15 and we get 20% faster than 13900KS and around 18% faster than 7950X.
In summary, ArrowLake vs Zen 4:
ST: ~12% faster than 7950X(3D)
MT: ~18% faster than 7950X and ~26% faster than 7950X3D
Gaming: up to few % faster than 7950X3D (if that) and 20% faster than 7950X
So vanilla Zen 5 has a really good chance to leapfrog ArrowLake if AMD manages to get at least 20% higher performance (IPC x clocks) in both ST and MT workloads, versus 7950X. Gaming should be even unless Zen 5 gets even better gaming uplift due to better front end and higher speed memory support. X3D variant of Zen 5 should be clearly ahead of any ArrowLake part, unless intel brings on some sort of stacked cache for it.
Edit: I expect Arrow Lake to have 20% higher IPC versus Raptor Lake while clocking at 5.3Ghz max. That makes it around ~5% faster than 6Ghz Raptor Lake refresh in ST.
For MT, the total gain of ~15% (from the slide) will likely be due to better E cores that have more IPC and clock higher.
Abwx
11,936
4,910
They also use Povray wich doesnt enable AVX2 for AMD, otherwise the 7950X would score 18% better in this test, so you get the picture of the actual ST perf for FP, since all three tests are FP...
tamz_msc
3,865
3,730
Which is funny ,since that leaked slide we saw awhile back showed 8+16 Arrow Lake-S with a PL2 of 250W.
Those were simulations/performance projections that IgorsLab leaked. It is very much possible that the v-f curve for whatever node - Intel or TSMC - that ARL uses gives better perf at lower iso-power than Intel 7 which really shines at higher iso-power.
My feeling is that if you could limit both RPL-refresh and ARL at 177 W PL2, ARL would be even faster than what the leaks indicate.
Oct 14, 2023
23
13
36
I feel like computerbase is something like the German version of userbenchmark. In multiple tests with different power limits they consistently have the 13900k on top in both MT and ST workloads in efficiency. That seems off?
SiliconFly
1,924
1,284
13900s are already on par with 7950X3D in power efficiency last year itself. 14900s should take it a bit further taking both performance & efficiency crowns.
But honestly, most aren't really excited by a vestigial product like RPL-refresh that shouldn't exist in this day & age (like rocket lake). I'm more looking forward towards MTL & ARL. RPL now in Q4 2023 is a disgrace.
19,203
Does the 14900K need the throttle limit to be raised to hit 6 GHz reliably? Me wonders...
Hulk
3,857
The question regarding power efficiency and the 14900K is not if it uses more power than the 13900K but how much power does it use at ISO frequencies on the same workloads. This is a hard question to answer because no one seems to do such testing. For example, try and and find a comparison between Alder Lake and Raptor Lake with the same number of P's and E's at at the same frequency.
Also, testing is complicated by the fact that there is a variation in parts due to binning (quality of silicon).
This leads to the next question regarding the Raptor Refresh, which is are these parts simply higher binned Raptor parts due to increase yields, or another refinement of Intel 7 (aka 10++++++++++++), or a combination of both?
Here's my take.
The Raptor Refresh is indeed a refinement of Intel 7, the last gasp for the hard-starting and long-lived Intel 10nm node... the one that has caused them so many problems but in the end pulled got across the finish line.
Increasing performance of parts down stack from the 13900K is pretty easy if yields/binning is better than a year ago. Increase clocks by 200MHz and add another E cluster to the 13700K.
The 14900K is a little trickier. It looks like this part will be 6GHz ST and 5.7GHz MT, with the E's at 4.4GHz. This IS marginally better than the 13900KS at what should be a markedly lower price.
Bringing a 14900KS to market will be tougher. 6.2GHz for some cherry parts is probably in the cards, but going higher than 5.7GHz all-core is going to be tough without selling the chip with a nuke reactor to power it and the associated nuke cooling to cool it.
I'll probably buy a 14900K if only to test it against the 13900K I used to have. I have a lot of data and can test the 14900K in the exact same system as the 13900K.
Finally, even though I've mainly been an Intel guy from a buying perspective over the years, there is NO comparison when it comes to Zen 4 and Raptor Lake efficiency. Zen 4 is a marvel of efficiency.
H433x0n
1,224
1,606
Here's my take.
It's +200mhz at iso power based on the published specs.
No, that s even worse for RPL because TSMC s process scale badly at higher TDP.
I know, I mean when you compare both at 125W isopower it will be closer than before since it has a +200mhz base clock.
Abwx
11,936
4,910
Efficency should be measured at same accomplished work wich mean at same throughput.
So far AMD has currently 60% better efficency and from the numbers we got Intel will increase efficency by 52% at best with their next process, so ARL could eventually be comparable as current AMD products on the DT side of thing but not for mobile, indeed Intel was cautious enough to state that their future mobile chip will be THEIR most efficient mobile chip ever but not THE, notice the nuance...
Reactions: CopernicusLazarus
Oct 14, 2023
23
13
36
Computerbase does these tests and intel is always the most efficient cpus on their testing. Here is the most recent testing they've done, the 13900k is the most efficient cpu they ever tested at 45w
