Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
eek2121
3,458
5,105
Meteor Lake leaks when? 🤣
Seriously, Meteor Lake is the first Intel CPU/architecture that has my interest in a long time, primarily since Intel will be on a competitive node for the first time in a long time.
I hope Intel does the responsible thing and “accidentally” leaks all the info ASAP.
19,203
Reactions: Tlh97 and moinmoin
DrMrLordX
23,114
13,215
It would have been a competitive node in 2022. 2023? Not so much.
dullard
26,185
4,841
Meteor Lake: the node will not be the exiting part. Sure, it will have a lot of new things that may or may not be relevant to you. But, Arrow Lake should follow very quickly and THAT will have a competitive node and is what peaks my interest.
trivik12
351
318
Meteor Lake is still a huge deal. first disaggregated Intel CPU with parts from multiple processes(Intel and TSMC). Plus TSMC N3 does not look like being used by any client CPUs. N3e wont be available until late next year or 2024. So Intel is competing with N4/5P rather than N3. So its not as bad as competing N5p against Intel 7 where there is a huge gulf.
poke01
4,605
5,916
Who else will be using N3 family in 2023 apart from Apple? The rest of the industry is still stuck on N5 family. Intel 4 will be fine in 2023.
DrMrLordX
23,114
13,215
Samsung
Mediatek
etc.
(okay Samsung may be using 3GAP and some N3, depending on how they handle their next-gen of Snapdragon mobile, but we'll see. Mediatek is almost guaranteed to continue to push the envelope with their Dimensity line)
poke01
4,605
5,916
Samsung
Mediatek
etc.
I have no faith in new Samsung nodes unless a major player uses them. (idc if its Samsung themselves, Intel, AMD, Nvidia or Apple uses them to prove their worth in perf and efficiency).
Mediatek will indeed use N3 but they irrlevent apart from a few chinese phones that use them in SE and Asian markets.
poke01
4,605
5,916
Mediatek is huge. They ship a ton of volume. Though they are somewhat more heavily weighted towards the budget market than e.g. Qualcomm.
yep they do volume but they are not a threat to Intel in mindshare like Apple and to a certain extent Qualcomm(If Nuvia ships in 2023).
Doug S
3,746
6,613
Those budget phones won't be using N3, only their small segment going into high end phones would. So they will use it, but it isn't like they'll be doing 10K wpm.
Why did no one mention Qualcomm? They would seem to be the obvious target for who (other than Apple) that would be using N3/N3E in volume in 2023, in products sold in the US/EU.
moinmoin
5,248
8,463
Probably because they showed they are not above their own greed of jumping to cheaper lesser nodes at Samsung to save money only to come back later to the leading node at TSMC after significant pre-payments. That process voided Qualcomm's role as a preferred customer at TSMC and it's doubtful Qualcomm would suddenly significantly invest in bleeding edge nodes for this to change.
Reactions: KompuKare
DrMrLordX
23,114
13,215
More to the point, Mediatek went straight for N4 with Dimensity while Qualcomm opted to play footsie with Samsung nodes again for Snapdragon 8 Gen 1 (Gen1+ uses N4).
Exist50
2,452
3,106
Well Qualcomm's supposed to be staying at TSMC for their next flagship, so it really wouldn't be surprising if they're one of the first to N3 around early '24.
DrMrLordX
23,114
13,215
Maybe they learned their lesson? Or maybe TSMC is cutting them a deal behind closed doors despite public reports of increased prices for wafers. In any case Qualcomm has some egg on their face over the whole Dimensity 9000/9000+ affair. Take a look at what's happening with the Asus ROG Phone 6: Asus is releasing a "faster" version of the ROG Phone 6 (called: "6D") using the Dimensity 9000+ despite the base ROG Phone 6 using the Snapdragon 8+ Gen 1. Ouch. Message sent, message received.
hemedans
298
170
There is faster Rog phone 6 "pro" with sd 8+ gen 1 and normal Rog phone 6.
Unless Mediatek shift to Nvidia Gpu they wont be able to challenge Adreno with Mali Gpu. In Mali Open Gl drivers are broken and Vulkan is not as good as Adreno one.
DrMrLordX
23,114
13,215
There's also the "6D" which is the fastest of them all:
Though I will concede (as does the article) that the Snapdragon 8+ Gen 1 is faster in graphics. So it's a polarizing choice. But Asus did what they did for a reason. Dimensity 9000+ is the last chip they're going to use in the 6-series of Asus ROG Phones, much like the last Rog Phone 5 used the Snapdragon 888+. Asus had to wait to release ROG Phone 6 until Qualcomm switched to TSMC N4 for the 8+ Gen 1 SoC. It's likely that they never liked the 888 or 888+.
Geddagod
1,617
1,665
Intel 4 is estimated to have HP cell density closer to TSMC 3nm than TSMC 5/4nm (wikichip). Obviously there are other indicators of how good a node is as well, but I highly doubt Intel 4 would be marginally worse than TSMC 5/4nm at any rate. Even if you look at perf, at the very least Intel 4 would be basically on par with TSMC 5/4 (if you consider TSMC 7nm ~ Intel 7) while an optimistic take would put Intel 4 perf at above even tsmc 3nm (if you consider TSMC 7nm ~ Intel 10nm SF). For power, Intel 4 once again takes the lead over TSMC 5nm, though if I remember correctly it might be behind TSMC 4nm.
All considered, I would say Intel 4 is as good as TSMC 5/4nm. And that should be good enough for 2023- their main competitor, AMD, isn't shifting to 3nm until 2024, for zen 5. And even then, we also know zen 5 is using TSMC 4nm in some cases, so....
Geddagod
1,617
1,665
Me personally, I'm more interested for Arrow Lake. Potential revamped architecture, built from the ground up like zen? Exciting stuff. And Intel might have a competitive node with Meteor Lake, but with AMD on 3nm in 2024 with zen 5 and Intel on 20A with Arrow Lake, Intel might end up having a node lead... Zen 5, new node and ground up arch vs Arrow Lake, new node and ground up arch, sounds to be one of the most exciting CPU battles in a while.
